TL68
#1 Posted : Wednesday, January 17, 2024 9:00:27 PM(UTC)
TL68
Sweden
Hi!
Sorry if this is already covered in some other thread and I missed it. If so please point me right.
So I am trying to build a countdown timer that counts down towards a starttime defined in a Google Sheets used as datasource.
What I want is to achieve is to replace the clocktime shown in the vMix tutorial:
Countdown timer to datasource time
Is this possible and if so how?
Thanks in advance for any help with this!
#2 Posted : Wednesday, January 17, 2024 11:00:13 PM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Put the data in an invisible textblock , read and convert it with a script to the proper format and put it in the appropriate textblock
TL68
#3 Posted : Wednesday, January 17, 2024 11:06:57 PM(UTC)
TL68
Sweden
Hi!
Thanks for responding! Unfortunately I do not know how to script :-(. Any chance you can help me out here with some basic samples?
I have the data source setup working and can make a hidden textblock in a title. But then..?
dmwkr
#4 Posted : Wednesday, January 17, 2024 11:14:43 PM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Also, if you have control over the Google Sheet, you can use an aditional column that computes the correct string for vMix Countdown to Time.
TL68
#5 Posted : Wednesday, January 17, 2024 11:36:27 PM(UTC)
TL68
Sweden
THanks! But not sure I understand... How do you mean that sheets would recalculate every second and then fetch that into a title? Would not that mean a lot of updates for the data source?
EDIT: YES NOW I UNDERSTAND! Sorry, late in the afternoon here in Sweden so brain is a bit slow
dmwkr
#6 Posted : Wednesday, January 17, 2024 11:46:09 PM(UTC)
dmwkr
No, just write "{0:07:00:00PM|HH:mm:ss}" into the Google Sheets cell. Or, if you prefer to only write "07:00:00PM" into the Google Sheet, use a second cell that computes "{0:07:00:00PM|HH:mm:ss}" for the vMix title.
thanks 1 user thanked dmwkr for this useful post.
TL68 on 1/17/2024(UTC)
TL68
#7 Posted : Wednesday, January 17, 2024 11:53:01 PM(UTC)
TL68
Sweden
Hahaha, right when you posted this I posted in the previous post that I figured this out myself!
One more question: is there any way to do this computation in 24h format and not need the AM/PM parameter?
EDIT: figured that one out too. I just use format 0:16:00 instead of 0:04:00 PM. No need to change any setting. Great!
Thanks for all help guys! Really appreciated!
#8 Posted : Thursday, January 18, 2024 1:42:35 AM(UTC)
"Scripting for dummies" post
T68 on 1/18/2024(UTC)
TL68
#9 Posted : Thursday, January 18, 2024 1:54:13 AM(UTC)
TL68
Sweden
Got the setup working now by doing the calculations for the Countdown to Time parameter in the sheets document I use as data source. Works like a charm!
