TL68
#1 Posted : Wednesday, January 17, 2024 9:00:27 PM(UTC)
TL68
Sweden
Hi!
Sorry if this is already covered in some other thread and I missed it. If so please point me right.
So I am trying to build a countdown timer that counts down towards a starttime defined in a Google Sheets used as datasource.
What I want is to achieve is to replace the clocktime shown in the vMix tutorial:
Countdown timer to datasource time
Is this possible and if so how?
Thanks in advance for any help with this!
#2 Posted : Wednesday, January 17, 2024 11:00:13 PM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Put the data in an invisible textblock , read and convert it with a script to the proper format and put it in the appropriate textblock
TL68
#3 Posted : Wednesday, January 17, 2024 11:06:57 PM(UTC)
TL68
Sweden
Hi!
Thanks for responding! Unfortunately I do not know how to script :-(. Any chance you can help me out here with some basic samples?
I have the data source setup working and can make a hidden textblock in a title. But then..?
dmwkr
#4 Posted : Wednesday, January 17, 2024 11:14:43 PM(UTC)
dmwkr
Also, if you have control over the Google Sheet, you can use an aditional column that computes the correct string for vMix Countdown to Time.
TL68
#5 Posted : Wednesday, January 17, 2024 11:36:27 PM(UTC)
TL68
Sweden
THanks! But not sure I understand... How do you mean that sheets would recalculate every second and then fetch that into a title? Would not that mean a lot of updates for the data source?
EDIT: YES NOW I UNDERSTAND! Sorry, late in the afternoon here in Sweden so brain is a bit slow
dmwkr
#6 Posted : Wednesday, January 17, 2024 11:46:09 PM(UTC)
dmwkr
No, just write "{0:07:00:00PM|HH:mm:ss}" into the Google Sheets cell. Or, if you prefer to only write "07:00:00PM" into the Google Sheet, use a second cell that computes "{0:07:00:00PM|HH:mm:ss}" for the vMix title.
thanks 1 user thanked dmwkr for this useful post.
TL68 on 1/17/2024(UTC)
TL68
#7 Posted : Wednesday, January 17, 2024 11:53:01 PM(UTC)
TL68
Sweden
Hahaha, right when you posted this I posted in the previous post that I figured this out myself!
One more question: is there any way to do this computation in 24h format and not need the AM/PM parameter?
EDIT: figured that one out too. I just use format 0:16:00 instead of 0:04:00 PM. No need to change any setting. Great!
Thanks for all help guys! Really appreciated!
#8 Posted : Thursday, January 18, 2024 1:42:35 AM(UTC)
"Scripting for dummies" post
T68 on 1/18/2024(UTC)
TL68
#9 Posted : Thursday, January 18, 2024 1:54:13 AM(UTC)
TL68
Sweden
Got the setup working now by doing the calculations for the Countdown to Time parameter in the sheets document I use as data source. Works like a charm!
Guest (6)
