Sebastian.onvista
#1 Posted : Wednesday, March 8, 2023 1:00:08 AM(UTC)
Sebastian.onvista
Germany
I would like to request a template for the Stream Deck XL. As I assume that many users are using a Stream Deck, I think that many other users would also be interested in being able to use such a template. If it is not possible or too time-consuming, it would be very helpful to have a tutorial on how to create something like this yourself. I have already inserted everything, but unfortunately, I am stuck with the vMixShortcutTemplate file and the text file in the diagrams folder. I do not know what needs to be entered there and what all of it means.
#2 Posted : Wednesday, March 8, 2023 3:12:01 AM(UTC)
Originally Posted by: Sebastian.onvista Go to Quoted Post
Streamdeck has 3 models with 3 different number of keys.
There is a possibility to have multipl folders (sort of layers) for aditional key functions
The keys can be asigned using the vMix plugin, the Streamdeck software , Companion software or a mix of them and dont neceseraly need to be vMix exclusive
What would a template be based on ?
Sebastian.onvista
#3 Posted : Wednesday, March 8, 2023 4:16:46 AM(UTC)
Sebastian.onvista
Germany
I use the Stream Deck XL with the vMix plugin. I have also set everything perfectly, but would like to save this setting and provide it with some kind of cover image, so that a colleague knows which buttons to press. I have never worked with Companion. Do not know me with it.
Sorry my English is not the best
#4 Posted : Wednesday, March 8, 2023 5:11:03 AM(UTC)
Ýou do realize that when using the vMix plugin using the Streamdeck on another computer or even the shortcuts defined on another streamdeck the key references wont match anymore ?
Using the streamdeck app just make a screenshot of your layout .
Stick to using the streamdeck presets instead of trying to create a vMix template for it
Similar Topics
Shortcut templates for 2nd Midi device (General Discussion)
by Curtis Martin 5/9/2019 3:11:11 AM(UTC)
