Joined: 8/9/2022(UTC) Posts: 11   Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hello, I would like to request a template for the Stream Deck XL. As I assume that many users are using a Stream Deck, I think that many other users would also be interested in being able to use such a template. If it is not possible or too time-consuming, it would be very helpful to have a tutorial on how to create something like this yourself. I have already inserted everything, but unfortunately, I am stuck with the vMixShortcutTemplate file and the text file in the diagrams folder. I do not know what needs to be entered there and what all of it means.
Originally Posted by: Sebastian.onvista  Hello, I would like to request a template for the Stream Deck XL. As I assume that many users are using a Stream Deck, I think that many other users would also be interested in being able to use such a template. If it is not possible or too time-consuming, it would be very helpful to have a tutorial on how to create something like this yourself. I have already inserted everything, but unfortunately, I am stuck with the vMixShortcutTemplate file and the text file in the diagrams folder. I do not know what needs to be entered there and what all of it means. Streamdeck has 3 models with 3 different number of keys. There is a possibility to have multipl folders (sort of layers) for aditional key functions The keys can be asigned using the vMix plugin, the Streamdeck software , Companion software or a mix of them and dont neceseraly need to be vMix exclusive What would a template be based on ?
I use the Stream Deck XL with the vMix plugin. I have also set everything perfectly, but would like to save this setting and provide it with some kind of cover image, so that a colleague knows which buttons to press. I have never worked with Companion. Do not know me with it. Sorry my English is not the best
I use the Stream Deck XL with the vMix plugin. I have also set everything perfectly, but would like to save this setting and provide it with some kind of cover image, so that a colleague knows which buttons to press. I have never worked with Companion. Do not know me with it. Sorry my English is not the best Ýou do realize that when using the vMix plugin using the Streamdeck on another computer or even the shortcuts defined on another streamdeck the key references wont match anymore ? Using the streamdeck app just make a screenshot of your layout . Stick to using the streamdeck presets instead of trying to create a vMix template for it
