Curtis Martin
#1 Posted : Thursday, May 9, 2019 3:11:11 AM(UTC)
Curtis Martin
I'm using an X-Keys 128 and an xkey 80 interface. When I go to Export shortcuts under templates, it's only showing a picture of my first device (the 128). How do I know if its exporting the shortcuts for the Channel 2 device as well? I don't wont blow away many hours of work to find that it didn't export the shortcuts for 2nd device.
Also, I get the impression that shortcuts are independent of presets. Meaning each preset file doesn't save the shortcut file as part of the preset. Is that right?
rudyengels
#2 Posted : Thursday, May 9, 2019 5:13:00 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Concerning the shortcuts...
Only the shortcut keys assigned as local are saved with a preset.
In the help file under Presets you can read what and what's not saved.
thanks 1 user thanked rudyengels for this useful post.
PI48895 on 5/14/2019(UTC)
