Shortcut templates for 2nd Midi device
Joined: 10/30/2018(UTC) Posts: 11  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I'm using an X-Keys 128 and an xkey 80 interface. When I go to Export shortcuts under templates, it's only showing a picture of my first device (the 128). How do I know if its exporting the shortcuts for the Channel 2 device as well? I don't wont blow away many hours of work to find that it didn't export the shortcuts for 2nd device.
Also, I get the impression that shortcuts are independent of presets. Meaning each preset file doesn't save the shortcut file as part of the preset. Is that right?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Concerning the shortcuts...
Only the shortcut keys assigned as local are saved with a preset.
In the help file under Presets you can read what and what's not saved.
 1 user thanked rudyengels for this useful post.
