10 Pages«<45678>»
ask
#101 Posted : Wednesday, July 2, 2014 1:57:33 AM(UTC)
ask
admin wrote:
ask wrote:
there are a lot of clicks and pops on the audio tracks from and of the sound sources.
If you create a recording of these sources, does it sound the same there?
If possible, provide a screenshot of the statistics window, the audio column should show if audio is being dropped.
The clicks and pops occur in a mpeg recording but wmv seems OK. I have sent you a screenshot at info at vmix.com.au
I can see the audio drops happening on both "live" audio and recorded files, and both when it is recording and when not recording.
Regards
#102 Posted : Wednesday, July 2, 2014 10:26:21 AM(UTC)
cutter07 wrote:
Something else I found with Desktop Capture. When I play a video (with MediaPlayer) and use Desktop Capture to get it into vMix and record the video the left and right audio channel are turned 180°.
I just did a test and I am not seeing this. Are you sure it's not this way in the source video being played?
How are you making sure there is no audio feedback?
cutter07
#103 Posted : Wednesday, July 2, 2014 2:20:40 PM(UTC)
cutter07
Hi Martin
The issue is on our side. One cable from the ext. Mixer had a wrong pin allocation.
You've my apologies.
#104 Posted : Thursday, July 3, 2014 5:48:43 AM(UTC)
A new update has been released (13.0.0.120)
http://www.vmix.com.au/download/vmix13preview.exe
Audio Jitter Correction
Some audio devices are not capable of low latency audio which vMix requires.
To help workaround this, every 20 seconds vMix will check these devices
and if the amount of dropped audio (clicks and pops) is high it will increase the latency
for that particular input. This will create better quality audio at the expense of being a little more delayed than usual.
Video Playback Issues
This update should hopefully resolve most playback issues.
However, there is an issue with MP4 recordings created in vMix under Windows 7.
(The duration on the audio track is incorrect)
This is fixed in Windows 8 but for recordings created under Windows 7, I will work on repair utility. In the meantime, playback will work, but with a delay for the audio to kick in when seeking.
Title Presets Import/Export
Import and Export of Title presets is now available in CSV format.
thanks 4 users thanked admin for this useful post.
pasingshot on 7/3/2014(UTC), ClementN on 7/3/2014(UTC), doggy on 7/3/2014(UTC), richardgatarski on 7/8/2014(UTC)
ask
#105 Posted : Thursday, July 3, 2014 7:52:21 AM(UTC)
ask
Hi. Suddenly now when adding an .mpg file as an input, or removing that input vMix becomes unresponsive and appears to freeze. Eventually the input appears and vMix comes back to life. This is the same file/s that I have been using to test the previous build. Adding other inputs seem fine but I have only tested with .wmv files and camera/audio inputs at this stage.
#106 Posted : Thursday, July 3, 2014 8:31:21 AM(UTC)
Is it possible to send me a copy of the file?
#107 Posted : Thursday, July 3, 2014 10:18:25 AM(UTC)
I've found the MPG issue and updated the installer above to include the fix.
It is still 13.0.0.120
pasingshot
#108 Posted : Thursday, July 3, 2014 12:07:15 PM(UTC)
pasingshot
Am I the only one person that vMix freezes with the new beta release (13.0.0.120)?? Thats happens since this morning when I downloaded the new instalation file. I haven't problem with frezze on the others releases.
ask
#109 Posted : Thursday, July 3, 2014 11:09:33 PM(UTC)
ask
Confirmed fixed. Good job! Don't you sleep? LOL
#110 Posted : Thursday, July 3, 2014 11:11:24 PM(UTC)
Please download the installer again. It was updated shortly after you downloaded it to fix this.
#111 Posted : Friday, July 4, 2014 6:14:04 AM(UTC)
Maybe a bug (.120)
when trying to setup recording mp4 and choosing NOT to record audio (uncheck) I get the following error when confirming:
Recording_OK_Button
Object reference not set to an instance of an object
ovinas
#112 Posted : Friday, July 4, 2014 9:04:45 AM(UTC)
ovinas
When you think it's simple you're free to program your own software. Your disrespectful demands are annoying.
#113 Posted : Friday, July 4, 2014 9:36:39 AM(UTC)
I have deleted the offending posts and sent him a formal warning.
Sorry you had to hear that sort of language ovinas.
In the past I have kept moderation to a minimum in the hope of encouraging
productive if sometimes lively discussion.
However, this incident and the increase in off-topic posts has made me think
a bit more moderation is required.
This is a reminder to everybody to keep discussions on topic and civil.
I will also do my part by making it clearer in the first post of a thread what can or cannot be posted.
Thanks,
doggy on 7/4/2014(UTC)
ClementN
#114 Posted : Friday, July 4, 2014 9:38:20 AM(UTC)
ClementN
Romania
Hello Martin,
I think there are some problems with displaying the "REC" "EXT" "STREAM" .
In my tests:
a) when "EXT" is on, the "STREAM" flag dissapear
b) when "STREAM" flag is visible, it is positioned over the Program screen ( on the right side)
P.S. - I really like the new design of those flags as they are more visible.
#115 Posted : Friday, July 4, 2014 9:58:55 AM(UTC)
Thanks for that, not sure how I missed it.
Hopefully we're on the home stretch now and only a handful of bug fixes
remain before the final release! So keep them coming!
Ernest Król
#116 Posted : Friday, July 4, 2014 2:48:15 PM(UTC)
Ernest Król
I want to disable Overlay4 for Fullscreen and Recording/External and enable it only for Fullscreen 2 but when a untick it for Fullscreen it is automatically ticked on Recording/External and vice versa. Is it bug or vMix/system limitation?
cutter07
#117 Posted : Sunday, July 6, 2014 6:48:30 AM(UTC)
cutter07
The new possibility to change the input on the fly is really nice.
The only thing I found when changing the input, the connected entry in the playlist get lost.
Ernest Król
#118 Posted : Monday, July 7, 2014 6:47:45 AM(UTC)
Ernest Król
Hi, I've tested vMix 13 yesterday and in audio engine happened strange artifacts
I was using Desktop Konnekt 6 firewire audio interface connected to PCI FW card (chipset is from Texas Instruments)
PS. the gap in audio was resetting "Audio Input"
#119 Posted : Monday, July 7, 2014 7:01:15 AM(UTC)
While I can't completely rule out a bug in vMix, it sounds a bit too analog in nature
to be caused by software. Perhaps the reset also reset something in the hardware.
richardgatarski
#120 Posted : Monday, July 7, 2014 4:17:35 PM(UTC)
richardgatarski
Been a dare devil this week and used v13.0.0.104 in a few real productions last week. On mistake we made many times was to start External instead of Streamer. I suggest that the buttons (bottom part of main window) would rather be labeled as:
[Setup][RECORD], [Setup][EXTERNAL], [Setup][STREAM]
(where former buttons Start is RECORD, EXTERNAL, STREAM)
Similar Topics
vMix 13 preview Shortcut key issue (General Discussion)
by IceStream 6/18/2014 7:05:42 PM(UTC)
10 Pages«<45678>»
