5 Pages«<2345>
#61 Posted : Tuesday, December 6, 2022 2:59:06 PM(UTC)
vMix Preview Update (26.0.0.23)
* Added Square (1:1) and Vertical (9:16) size options for MP4 Recording
* Added ability to select audio channels (2 or 4) to export from Replay in either AVI or MP4.
This allows direct upload to services that do not support 4 channel videos.
* Fixed Mix Input aspect ratio issues when using non-widescreen productions
* Fixed Mix Input transition button not lighting up during transition
* Fixed main mix transition buttons not lighting up in some situations
* Now prompts to save existing preset when clicking New
* Added support for 7680x4320 for Decklink 8K Pro card
thanks 7 users thanked admin for this useful post.
eduardocfs on 12/6/2022(UTC), jet on 12/6/2022(UTC), nikosman88 on 12/6/2022(UTC), monamiga on 12/7/2022(UTC), sinc747 on 12/8/2022(UTC), raugert on 12/9/2022(UTC), stigaard on 12/15/2022(UTC)
RichShumaker
#62 Posted : Friday, December 9, 2022 10:46:04 AM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
Woohoo 9:16 recording booo 1:1 just kidding that's cool too.
Not sure if this is a "Bug" or "feature".
I am using Virtual PTZ on a Mix Input and then trying to save the virtual Input for location data for a transition Yes this would be a Transition of a Mix, not to be confused with a Mix Transition(Inside the Mix Input itself).
When I PTZ the Mix Input the virtual input moves as well.
I have a feeling that these two things do not work the way I am envisioning them working.
Thanks in advance for the help.
RichShumaker
#63 Posted : Friday, December 9, 2022 10:54:56 AM(UTC)
RichShumaker
I was joking about it on a group but actually could we have a 1:1 grid like the 9:16 one in Preview? It may already be there as I have not tried to do a 1:1 production yet.
Heck if you are adding aspect ratios for recording, you might want to add 35 film, which is 3:2.
jet
#64 Posted : Friday, December 9, 2022 9:07:59 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
There seems to be a bug in "Mini mixer" aka Mix Input.
Triggering Mini mixer transition with a shortcut gives unespected results. Noticed also that Mini mixer output is set to none when the shortcut is executed.
#65 Posted : Friday, December 9, 2022 9:49:50 PM(UTC)
Hi Jet can you be specific about the settings ?
when shortcut function is set to a transition , input to preview and Mix to the number of the mix all seems just fine
jet
#66 Posted : Friday, December 9, 2022 10:01:32 PM(UTC)
jet
Hi Doggy.
I will make a video about the issue tomorrow if necessary.
Kind regards,
J
jet
#67 Posted : Sunday, December 11, 2022 7:01:22 AM(UTC)
jet
"Mini mixer" aka Mix Input -bug
Here is the video
https://app.knowmia.com/JouC
#68 Posted : Sunday, December 11, 2022 9:13:32 AM(UTC)
Here is the video
My previous answer still stands : your input setting for your merge shortcut should be set to preview!
SaltCreek
#69 Posted : Monday, December 12, 2022 3:14:40 AM(UTC)
SaltCreek
I am ready for the 2 channel audio export from replay. Allows quick upload to social without extra steps. Unless someone has a workaround for me?
jet
#70 Posted : Monday, December 12, 2022 8:58:49 PM(UTC)
jet
Here is the video
Please demonstrate.
The whole point is to trigger the effect on "Mini Mixer" / "Mix Input" not on the main mix.
#71 Posted : Monday, December 12, 2022 9:18:17 PM(UTC)
Please demonstrate.
There is nothing to demonstrate ! As mentioned before the input of the shortcut has to be set to PREVIEW (NOT the Mix input) and Mix to 2 ( or whatever Mix number you are using
Screenshot 2022-12-12 121710.jpg (24kb) downloaded 3 time(s).
jet on 12/12/2022(UTC)
jet
#72 Posted : Monday, December 12, 2022 9:28:17 PM(UTC)
jet
Please demonstrate.
Thanks Doggy!
Maybe the documentantion could be little more detailed and include more examples?
Kind regards,
J
RichShumaker
#73 Posted : Tuesday, December 13, 2022 6:50:22 AM(UTC)
RichShumaker
We'll be fixing the missing vertical recording option in the next preview update.
Awesome. Thanks. And I tried the VV recording and it works. Also I saw the 1:1 Grids that have probably been there forever.
Thanks as always.
gostreamworks
#74 Posted : Tuesday, December 13, 2022 9:02:13 PM(UTC)
gostreamworks
Just some quick feedback on the multiple audio track SRT. It seems that the PIDs are being generated in an unconventional way. Usually it is 256 (video) and 257+ for each audio track. It seems that vMix is doing the first audio track at 256 and then the last track as video. While this works for some applications, it might be best to stick the usual convention. See below report:
a1 aac stereo (131kbps) pid: 256
a2 aac stereo (130kbps) pid: 257
a3 aac stereo (131kbps) pid: 258
a4 aac stereo (131kbps) pid: 259
v1 h264 1920x1080 pid: 260
EDIT - better yet if we could set the PIDs (see below screenshot - just audio and video needed) I think that would solve a lot of issues as something will always deviate from the unwritten "norm" of PIDs
undefined - Imgur.png (86kb) downloaded 3 time(s).
#75 Posted : Wednesday, December 14, 2022 12:14:57 PM(UTC)
Just a quick reminder again, that feature requests are not permitted in this thread.
Any feature requests posted here by mistake will be deleted.
Please keep the discussion to vMix 26 features and bug reports only.
Thanks,
gostreamworks on 12/14/2022(UTC)
Roy Sinclair
#76 Posted : Thursday, December 15, 2022 9:20:50 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Bug in V25, may or may not be fixed in V26 but if not fixed it should be.
I just spent an hour trying to figure out why a shortcut to a scrpt refused to start the script. It turns out the NAME of the script had a trailing space character. A quick check shows that script names are never checked for trailing spaces in any input so it would have worked if I had also put a trailing space on the script name in the shortcut.
#77 Posted : Thursday, December 15, 2022 12:22:42 PM(UTC)
Hi Roy,
I can confirm that is not a bug as spaces are supported in script names.
So if an additional space is added, then that also needs to be added to any shortcut referring to it.
eduardocfs on 12/15/2022(UTC)
Roy Sinclair
#78 Posted : Monday, December 19, 2022 9:48:04 AM(UTC)
Roy Sinclair
Hi Roy,
Spaces within a name yes, that's a feature thank you very much but a space at the END of the script name? No, I call that a bug because it's not readily visible.
robertskiba
#79 Posted : Monday, December 19, 2022 9:18:33 PM(UTC)
robertskiba
Germany
Hi Roy,
It would be so easy to fix as they would only need to crop leading and trailing spaces. Or indicate them. Had that experience, too. It came from copy&paste.
gpdipalmerahtimur
#80 Posted : Tuesday, December 20, 2022 11:19:16 AM(UTC)
gpdipalmerahtimur
Indonesia
Hi Martin,
Does Global Shortcut requires us to set Key/Control (eg. F1, F2, 'M', etc.) to be Available on Web Controller? How if we run out of Keys?
Thanks in advance.
Guest (14)
5 Pages«<2345>
