Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
vMix Preview Update (26.0.0.23)
* Added Square (1:1) and Vertical (9:16) size options for MP4 Recording * Added ability to select audio channels (2 or 4) to export from Replay in either AVI or MP4. This allows direct upload to services that do not support 4 channel videos. * Fixed Mix Input aspect ratio issues when using non-widescreen productions * Fixed Mix Input transition button not lighting up during transition * Fixed main mix transition buttons not lighting up in some situations * Now prompts to save existing preset when clicking New * Added support for 7680x4320 for Decklink 8K Pro card
 7 users thanked admin for this useful post.
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Woohoo 9:16 recording booo 1:1 just kidding that's cool too.
Not sure if this is a "Bug" or "feature".
I am using Virtual PTZ on a Mix Input and then trying to save the virtual Input for location data for a transition Yes this would be a Transition of a Mix, not to be confused with a Mix Transition(Inside the Mix Input itself).
When I PTZ the Mix Input the virtual input moves as well.
I have a feeling that these two things do not work the way I am envisioning them working.
Thanks in advance for the help.
I was joking about it on a group but actually could we have a 1:1 grid like the 9:16 one in Preview? It may already be there as I have not tried to do a 1:1 production yet.
Heck if you are adding aspect ratios for recording, you might want to add 35 film, which is 3:2.
Joined: 11/14/2012(UTC) Posts: 408  Location: Finland Thanks: 270 times Was thanked: 40 time(s) in 38 post(s)
There seems to be a bug in "Mini mixer" aka Mix Input.
Triggering Mini mixer transition with a shortcut gives unespected results. Noticed also that Mini mixer output is set to none when the shortcut is executed.
Originally Posted by: jet  There seems to be a bug in "Mini mixer"
Triggering Mini mixer transition with a shortcut gives unespected results. Noticed also that Mini mixer output is set to none when the shortcut is executed. Hi Jet can you be specific about the settings ? when shortcut function is set to a transition , input to preview and Mix to the number of the mix all seems just fine
Originally Posted by: doggy  Originally Posted by: jet  There seems to be a bug in "Mini mixer"
Triggering Mini mixer transition with a shortcut gives unespected results. Noticed also that Mini mixer output is set to none when the shortcut is executed. Hi Jet can you be specific about the settings ? when shortcut function is set to a transition , input to preview and Mix to the number of the mix all seems just fine Hi Doggy. I will make a video about the issue tomorrow if necessary. Kind regards, J
Originally Posted by: jet  My previous answer still stands : your input setting for your merge shortcut should be set to preview!
I am ready for the 2 channel audio export from replay. Allows quick upload to social without extra steps. Unless someone has a workaround for me?
Originally Posted by: doggy  Originally Posted by: jet  My previous answer still stands : your input setting for your merge shortcut should be set to preview! Please demonstrate. The whole point is to trigger the effect on "Mini Mixer" / "Mix Input" not on the main mix.
Please demonstrate.
There is nothing to demonstrate ! As mentioned before the input of the shortcut has to be set to PREVIEW (NOT the Mix input) and Mix to 2 ( or whatever Mix number you are using  Screenshot 2022-12-12 121710.jpg (24kb) downloaded 3 time(s).
Please demonstrate.
There is nothing to demonstrate ! As mentioned before the input of the shortcut has to be set to PREVIEW (NOT the Mix input) and Mix to 2 ( or whatever Mix number you are using Thanks Doggy! Maybe the documentantion could be little more detailed and include more examples? Kind regards, J
Originally Posted by: admin  We'll be fixing the missing vertical recording option in the next preview update. Awesome. Thanks. And I tried the VV recording and it works. Also I saw the 1:1 Grids that have probably been there forever. Thanks as always.
Joined: 9/21/2018(UTC) Posts: 23 Location: United Arab Emirates
Just some quick feedback on the multiple audio track SRT. It seems that the PIDs are being generated in an unconventional way. Usually it is 256 (video) and 257+ for each audio track. It seems that vMix is doing the first audio track at 256 and then the last track as video. While this works for some applications, it might be best to stick the usual convention. See below report: a1 aac stereo (131kbps) pid: 256 a2 aac stereo (130kbps) pid: 257 a3 aac stereo (131kbps) pid: 258 a4 aac stereo (131kbps) pid: 259 v1 h264 1920x1080 pid: 260 EDIT - better yet if we could set the PIDs (see below screenshot - just audio and video needed) I think that would solve a lot of issues as something will always deviate from the unwritten "norm" of PIDs  undefined - Imgur.png (86kb) downloaded 3 time(s).
Just a quick reminder again, that feature requests are not permitted in this thread. Any feature requests posted here by mistake will be deleted.
Please keep the discussion to vMix 26 features and bug reports only.
Thanks,
Martin vMix
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Bug in V25, may or may not be fixed in V26 but if not fixed it should be.
I just spent an hour trying to figure out why a shortcut to a scrpt refused to start the script. It turns out the NAME of the script had a trailing space character. A quick check shows that script names are never checked for trailing spaces in any input so it would have worked if I had also put a trailing space on the script name in the shortcut.
Hi Roy,
I can confirm that is not a bug as spaces are supported in script names. So if an additional space is added, then that also needs to be added to any shortcut referring to it.
Martin vMix
Martin vMix Spaces within a name yes, that's a feature thank you very much but a space at the END of the script name? No, I call that a bug because it's not readily visible.
Joined: 8/22/2021(UTC) Posts: 48   Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
Martin vMix Spaces within a name yes, that's a feature thank you very much but a space at the END of the script name? No, I call that a bug because it's not readily visible. It would be so easy to fix as they would only need to crop leading and trailing spaces. Or indicate them. Had that experience, too. It came from copy&paste.
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Hi Martin,
Does Global Shortcut requires us to set Key/Control (eg. F1, F2, 'M', etc.) to be Available on Web Controller? How if we run out of Keys?
Thanks in advance.
