Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Originally Posted by: admin  vMix Preview Update (26.0.0.20)
* Transition buttons will now highlight red during transitions don't work with transitions to video inputs
Joined: 1/13/2010(UTC) Posts: 5,304  Location: Gold Coast, Australia Was thanked: 4674 time(s) in 1609 post(s)
Originally Posted by: jet  Originally Posted by: doggy  Originally Posted by: jet  There seems to be a bug in 26.0.0.20 that causes wrong image size / aspect ratio in mix-inputs. Can simulate when setting the aspect ratio of the Mix itself wrongly set or mess with the main position settings of it Project set as standard PAL anamorphic 16:9 (720x576) Yes, it seems to work if set to 1024x576 (16:9) "true" widescreen Anamorphic is not the right setting to use, you are looking for Widescreen which can be used with 720x576. Anamorphic is wider than widescreen and only really for use with film content (i.e for movies where you see black bars on the top and bottom when watching on an already widescreen TV)
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Originally Posted by: admin  vMix Preview Update (26.0.0.20)* Fixed new Mix activators * Transition buttons will now highlight red during transitions* Fixed Mix input UI not loading correctly from preset * Audio Mixer settings now reset to default correctly when selecting New preset * Copy/Paste buttons added to Input Position tab * Input Names now update correctly on Mix inputs when changed To update, run vMix Update, or use the download link again: https://cdn.vmix.com/download/vmix26preview.exe Will it be possible to pull the "Transition in progress" via the API as a flag or remaining time? /Peter
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Using vMix HD Basic 26.0.0.18 version then I updated to 26.0.0.20 and it still existed Setup 1. Input One is an Audio Input. 2. On Input One I am using MultiView(Layers) and have a Layer Selected and resized I hit the overlay button for 1 and it goes Red BUT it does not show up on the output screen. Image of Issue for vMix Basic Overlay
Rich,
Basic HD does not support layers in overlays. This is so users can't bypass the 1 overlay limit in this version.
Originally Posted by: admin  Rich,
Basic HD does not support layers in overlays. This is so users can't bypass the 1 overlay limit in this version. EDIT After some thought I completely get it. I am an advocate for NOT using the PRO version to start as it is overwhelming for many people. I want people to start on vMix HD Basic and learn and try to push the boundries as far as possible. I outgrew vMix HD Basic the first day but needed to use it for I think a year or so before winning a 4k version. Having Layers will allow many to avoid upgrading and I totally understand the decission to limit that. I was hoping to start introducing concepts like a "Master Input" when I start making tutorials for vMix HD Basic as I find that to be one of the most powerful things in vMix. A Master Input is an Input of Inputs that you can 'Merge" between. Of course you are very limited with 4 Inputs for this concept. And teaching it shows why upgrading is very helpful except I also see how you could "exploit" it if you don't need more than 4 Inputs for some reason. Thanks Again, original post below. Original Below Well that stinks and thanks for the update on that. I see them as two different things except I understand how you could use Layers as "overlays". I was just creating different "look" using only 4 Inputs by resizing an input via layers. I am sure this was a decission made long ago to avoid people from just purchasing the entry level product. Since I am a big fan of vMix HD Basic I have to ask, any chance of reversing this decision as I think the 4 Input Limit really is limiting and the layers options just makes things more flexible with those 4 inputs. Thanks again for this information.
Is it possible to install V26 preview in a separate folder without interfering with V25? I'd like to start testing some of the new features but need to make sure my production version will continue to work.
Joined: 12/27/2012(UTC) Posts: 5,498  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: jakent  Is it possible to install V26 preview in a separate folder without interfering with V25? I'd like to start testing some of the new features but need to make sure my production version will continue to work. yes (last preset will be the same for both though)
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
Originally Posted by: jakent  Is it possible to install V26 preview in a separate folder without interfering with V25? I'd like to start testing some of the new features but need to make sure my production version will continue to work. Yes. If you create a new User account with administrator privileges, your user settings and last preset will be separate from your main vMix 25 set-up. They are stored in the User's account folder. You should install V26 preview in a separate folder, thus not interfering with V25.
 1 user thanked BETech for this useful post.
Hello from barcelona
I was really looking forward to the blur option, but I see that unfortunately it is not applicable to multiview layers.
I use the Merge function a lot for smooth transitions between scenes. It would be very useful to be able to clone an input and apply a blur change to only some specific layers. Then the transition between them would be smooth and organic.
Thanks Can you please show example of input layouts and their merge you are refering to . Maybe using Mixes could be of use Preferably in a separate post
https://vimeo.com/775311749/56e57645b0I have prepared a quick example. I have removed the audio and hidden the logo because it is part of a job. What you have here is an input made up of several layers. 1.- 3D background (png) 2.- A MIX input placed on top of the background, which is the TV. In it I can change the inputs that I show. 3.- The presenter with chroma 4.- A version of the chroma changed to black and distorted to shadow mode (behind the previous one). I have another input that is a copy of this one adjusting the zoom level, a bit of distortion, etc. The result is that if I make a slow merge of 3s between the far view, the near view and then a merge with the MIX that appears on the screen, it makes this smooth transition between them. So I simulate that the camera is getting closer. What I would like is that in the input copy where I simulate the zoom, I can apply a blur to everything except the speaker, so I can simulate depth of field. And that when I merge the blur would make the transition as it does with other attributes such as position, rotation, etc.
Originally Posted by: linkaman  https://vimeo.com/775311749/56e57645b0I have prepared a quick example. I have removed the audio and hidden the logo because it is part of a job. What you have here is an input made up of several layers. 1.- 3D background (png) 2.- A MIX input placed on top of the background, which is the TV. In it I can change the inputs that I show. 3.- The presenter with chroma 4.- A version of the chroma changed to black and distorted to shadow mode (behind the previous one). I have another input that is a copy of this one adjusting the zoom level, a bit of distortion, etc. The result is that if I make a slow merge of 3s between the far view, the near view and then a merge with the MIX that appears on the screen, it makes this smooth transition between them. So I simulate that the camera is getting closer. What I would like is that in the input copy where I simulate the zoom, I can apply a blur to everything except the speaker, so I can simulate depth of field. And that when I merge the blur would make the transition as it does with other attributes such as position, rotation, etc. Use a Mix with original background and a virtual of the background but blurred for your multiview on a coloured based inputs When doing the merge fade the Mix (double shortcut= one to de merge and one to fade the mix so both are simultanious)
Originally Posted by: doggy  Originally Posted by: linkaman  https://vimeo.com/775311749/56e57645b0I have prepared a quick example. I have removed the audio and hidden the logo because it is part of a job. What you have here is an input made up of several layers. 1.- 3D background (png) 2.- A MIX input placed on top of the background, which is the TV. In it I can change the inputs that I show. 3.- The presenter with chroma 4.- A version of the chroma changed to black and distorted to shadow mode (behind the previous one). I have another input that is a copy of this one adjusting the zoom level, a bit of distortion, etc. The result is that if I make a slow merge of 3s between the far view, the near view and then a merge with the MIX that appears on the screen, it makes this smooth transition between them. So I simulate that the camera is getting closer. What I would like is that in the input copy where I simulate the zoom, I can apply a blur to everything except the speaker, so I can simulate depth of field. And that when I merge the blur would make the transition as it does with other attributes such as position, rotation, etc. Use a Mix with original background and a virtual of the background but blurred for your multiview on a coloured based inputs When doing the merge fade the Mix (double shortcut= one to de merge and one to fade the mix so both are simultanious) Not a bad idea. But it would certainly be much better if the filters could be applied to each layer of the multiview. As it happens for example in OBS, in a scene you have different sources and you can apply filters to each of them. Or I'd be happy if when doing a Merge, the strength parameter is adjusted progressively as it happens with position, zoom, ... It would give a lot more creative options.
Can you record a 9:16(vertical video) production as 1080 X 1920?
I know you can Center Cut a Stream except I could not figure out either check box or drop down how to do a VV recording.
Originally Posted by: RichShumaker  Can you record a 9:16(vertical video) production as 1080 X 1920?
I know you can Center Cut a Stream except I could not figure out either check box or drop down how to do a VV recording. I could not figure it out so I did 2 things. I created an Overlay Mask with Black on the sides(reverse letterboxing) so that the 2/3 of the image that is getting cut uses almost Zero space on the record. The second thing I had to do was a Transcode and I used AVIdemux Crop Feature to do this. It was fairly easy except it does add a step in post. I wonder if there might be a way to do this Trascode using the Hamburger Button "Video Tools" with a Convert to 9:16 Feature. Just an idea. This is still not a direct export situation which I was hoping for to speed up the production to release scehdule and it requires a "fix it in post" workflow. EDIT I still appreciate the new 9:16 VV Workflow very much and I love the new 90 degree turn button.
We'll be fixing the missing vertical recording option in the next preview update.
Originally Posted by: admin  We'll be fixing the missing vertical recording option in the next preview update. When will there be a new preview?
Originally Posted by: biebb  Originally Posted by: admin  We'll be fixing the missing vertical recording option in the next preview update. When will there be a new preview? Really? Yesterday of course!
Not a show stopper, but have noticed inconsistent behavior of the transition highlight when using external controllers. Sometime the fade button will light, other times not. Works as designed when using the GUI. Cheers. Andrew,
