10 Pages«<23456>»
cutter07
#61 Posted : Tuesday, June 24, 2014 2:05:53 PM(UTC)
cutter07
First I want to say that I'm really happy with the new audio enhancement.
To prevent mouse click by fault on the bus buttons (M, A, B) I would recommend to expand the lock button with this functionality.
A little issue I found by adding a shortcut as usual and then after changing this shortcut to "Local Shortcut" vMix adds three times the same shortcut.
If the audio mixer is unpinned and placed in the middle of the vMix Window and you close vMix, then you have no chance to hit the yes button to close vMix because the audio mixer is over the messagebox window.
asnplus
#62 Posted : Tuesday, June 24, 2014 11:52:09 PM(UTC)
asnplus
Quick fix to the shortcut issue. Double click to edit instead of highlighting it and selecting edit.
yundin
#63 Posted : Wednesday, June 25, 2014 3:19:56 PM(UTC)
yundin
New version wont save saturation setting on any input. Preset open with desaturated input. (may be comma separate in digit value in the preset file) Pls fix it
ClementN
#64 Posted : Wednesday, June 25, 2014 3:57:10 PM(UTC)
ClementN
Romania
I can not login into the ScaleEngine account from the Streaming window.
Nothing happen when I push the "Login and Update Channels".
#65 Posted : Wednesday, June 25, 2014 11:22:26 PM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
ClementN,
When typing in your login details and clicking Login and Update Channels, the channels list
should be filled in with channels available on your account. If the channel list is empty
contact ScaleEngine to see if your account has been activated.
imagengroup
#66 Posted : Thursday, June 26, 2014 1:41:38 AM(UTC)
imagengroup
la nueva version tiene problema en la reproduccion de audio.
#67 Posted : Thursday, June 26, 2014 1:46:39 AM(UTC)
Please provide a detailed description of the problem. Simply saying "doesn't work" is not very helpful...
#68 Posted : Friday, June 27, 2014 1:18:28 PM(UTC)
Please submit a detailed request over in Feature Requests for vMix 14.
As mentioned at the start of this thread, there will be no additional new features going into vMix 13.
madness
#69 Posted : Saturday, June 28, 2014 10:16:59 PM(UTC)
madness
Happy to say that I finally got .104 to download, installed, and it's working properly.
Something I now recall I recalled after installation, the previous install gave me errors stating that it couldn't overwrite a file ending in .au or was it .ax???? I don't recall, but I didn't get it with this install. Appears that problem is resolved.
Thanks Martin!
#70 Posted : Saturday, June 28, 2014 11:45:32 PM(UTC)
I've moved a bunch of posts into new Feature Requests threads.
Please keep this discussion to current vMix 13 features and bug reports.
Additional features should not be suggested here. The only exception is minor tweaks or adjustments to existing features.
#71 Posted : Sunday, June 29, 2014 4:41:38 AM(UTC)
Input position :
What is the logic behind a 'Reset All' but X and Y not resetting (while on Z)when clicked ?
#72 Posted : Sunday, June 29, 2014 9:14:41 AM(UTC)
doggy wrote:
Input position :
This is a bug that will be fixed...
doggy on 6/29/2014(UTC)
joe1378
#73 Posted : Sunday, June 29, 2014 10:52:50 AM(UTC)
joe1378
Thanks Martin!
when you reinstall vmix you have to close the browser(Chrome,ie,firefox)
Josu3 Olvera
madness
#74 Posted : Sunday, June 29, 2014 7:51:45 PM(UTC)
madness
Thanks Martin!
Josu3 Olvera
Interesting. One of the few programs that require this. Perhaps in the installer, there should be a note of this, like in the other software that do require the browsers to be closed.
#75 Posted : Sunday, June 29, 2014 10:03:33 PM(UTC)
The first window of the installer notes that all programs should be closed.
madness
#76 Posted : Monday, June 30, 2014 4:13:32 PM(UTC)
madness
Thanks again Martin, Guess it didn't stand out well enough for me.
#77 Posted : Tuesday, July 1, 2014 5:29:19 AM(UTC)
New and perhaps final Beta update of vMix 13 is now available (13.0.0.117)
http://www.vmix.com.au/download/vmix13preview.exe
Changes and fixes:
* Added support for Elgato Game Capture and LGP Stream Engine
Users should be aware these devices add a significant delay.
* Improved MultiCorder recordings with support for most capture cards
* Ability to create new recording every x minutes now available for all formats
including MultiCorder. Great for AVI and MP4 which are difficult to recover if power is lost.
* Made clear in Basic / Basic HD that List is not available. Also
disabled 2,3,4 overlay buttons in these editions.
* Fixed up some issues when resetting settings to default
* Fixed video playback issues
* Fixed issues with Solo button when adding and removing inputs
* Fixed issues with List input with new audio engine
* New REC, EXT and STREAM notification icons underneath Output preview.
* Audio busses can not be changed when in Lock mode.
* Clarified naming of Audio Outputs and added None option
* Fixed Saturation not saving on systems other than English
Please report any bugs and issues. If all goes well the final release will be out soon.
ClementN on 7/1/2014(UTC)
#78 Posted : Tuesday, July 1, 2014 5:58:18 AM(UTC)
I think there is (still)a major bug
it concerns playback of mp4 clips (recorded with vMix too)
when clip is being played and one changes the playhea the video freezes and also possible transitions are freezing unless when one previews another one.
once that one is repositioned the same thing happens and one can not use either one of them anymore . restarting helps in the sence that the audio starts form the beginning but no videoplay ( stuck on same frame) . transition are still blocked
edit : changing playback speed creates same issue
in v12 all is well in that matter
#79 Posted : Tuesday, July 1, 2014 7:57:53 AM(UTC)
Could you go to Input Properties -> Advanced tab and report what codec it is using for MP4?
The default is the Microsoft decoder which works fine for me, so I suspect a weird video or codec is causing the problem.
#80 Posted : Tuesday, July 1, 2014 8:24:40 AM(UTC)
this is what I get :
Audio Renderer
Video Mixing Renderer 9
Audio Processor
LAV video Decoder
Microsoft DTV-DVD Audio Decoder
(videoname)
Guest (20)
Similar Topics
vMix 13 preview Shortcut key issue (General Discussion)
by IceStream 6/18/2014 7:05:42 PM(UTC)
10 Pages«<23456>»
