fenki86
#1 Posted : Monday, June 16, 2014 5:47:35 PM(UTC)
fenki86
Rank:: Advanced Member
GoPro seems to be working via VLC. Anyone can try to catch the feed via vMix? Or is there just no option for that?
https://forum.videolan.o...pic.php?f=4&t=109050
Thremir
#2 Posted : Monday, June 16, 2014 6:27:46 PM(UTC)
Thremir
I've tried importing a GoPro Hero 3 stream into vMix with success actually.
The footage received however, was not usable at all.
This would be because a GoPro WiFi stream is highly compressed and has lots of delay. This would be because it is not meant to show live high quality footage, but as a low resolution monitor for checking the angle of the camera on the go with a mobile application.
Also, the GoPro unit itself doesn't have the processing power to encode a higher quality video stream.
Hope this answers your question.
Cheers,
Håvard
thanks 1 user thanked Thremir for this useful post.
fenki86 on 6/17/2014(UTC)
Thremir
#3 Posted : Monday, June 16, 2014 6:30:59 PM(UTC)
Thremir
And if you wondered how, that would have been through VLC's streaming feature with the GoPro as input, running a local stream to vMix, adding even more delay...
fenki86
#4 Posted : Tuesday, June 17, 2014 10:45:20 AM(UTC)
fenki86
thanks for the reply... in fact that helps a lot... in that case the easiest way for a goal-cam would be an ip-cam or a GoPro (or any other actioncam) attached to a Teradek Cube/Vidiu.
richardgatarski
#5 Posted : Tuesday, June 17, 2014 10:54:46 AM(UTC)
richardgatarski
I tried a little with GoPro black, and did not even get a descent video signal via HDMI.
Maybe me, googled for a while and it seems that GoPro is best suited for internal recording.
Please correct me if I am wrong.
Thremir
#6 Posted : Tuesday, June 17, 2014 11:39:02 AM(UTC)
Thremir
I made a little video for you to decide. I think its decent, but nothing more. Lots of handy-cams can deliver better image quality over the HDMI than this.
https://www.youtube.com/watch?v=gLiabap-mP4&feature=youtu.be
(Read the video description for settings)
Cheers,
Håvard
richardgatarski on 6/17/2014(UTC)
richardgatarski
#7 Posted : Tuesday, June 17, 2014 12:24:39 PM(UTC)
richardgatarski
Thanks Håvard,
More like a still image than a video ;) But what I saw looked pretty OK.
Can't really remember what kind of issues I had with GoPro HDMI out in to vMix. Might have been stuttering, or pixelation, or something else. I just gave up as it is not important for us at the moment.
fenki86
#8 Posted : Friday, June 20, 2014 1:38:28 PM(UTC)
fenki86
Thanks Håvard,
one simple question. The video shown - how did you capture that? Did you send the signal from the GoPro HDMI-Output via cable or via transmitter (f.e. Teradek Cube)? Or was it with the included Wifi-Connection?
Thanks for clearing that up.
Thremir
#9 Posted : Friday, June 20, 2014 3:06:27 PM(UTC)
Thremir
Because I don't own a GoPro 3 nor a WiFi backpack for mine (I did the whole GoPro 3 WiFi testing with my friends GoPro), I have to go for the Hero 2's Mini-HDMI output onto my Intensity Pro card in my production PC.
(horrible quality) Pics below.
https://drive.google.com...sMTRIejg&usp=sharing
instudiomedia
#10 Posted : Wednesday, July 2, 2014 11:47:35 AM(UTC)
instudiomedia
Maybe this is helpfull to you
thanks 1 user thanked instudiomedia for this useful post.
OpenROADer on 7/7/2014(UTC)
Similar Topics
GoPro Cineform alpha video problem (General Discussion)
by omnisound 4/11/2021 1:42:59 AM(UTC)
GoPro Hero9 or 8 webcam (Hardware Compatibility)
by Speegs 9/18/2020 1:31:01 PM(UTC)
Gopro to vmix via wifi, good solution found. (3rd Party Software and Development)
by spino 5/2/2020 3:55:36 AM(UTC)
GoPro Hero 7 Silver (Hardware Compatibility)
by sacchin 2/24/2020 9:17:12 PM(UTC)
GoPro framerate issue (Hardware Compatibility)
by -TA_ 1/18/2019 10:49:55 PM(UTC)
GoPro and NDI possible? (Hardware Compatibility)
by jtoney 11/22/2018 4:53:27 AM(UTC)
Anyone tried the xiaomi yi action cam instead of the gopros? (Hardware Compatibility)
by Cormac 6/19/2016 4:24:27 PM(UTC)
Blackmagic DeckLink and GoPro Hero 4 (Hardware Compatibility)
by pts211 10/30/2015 9:38:15 AM(UTC)
gopro 3 black with vmix? (Hardware Compatibility)
by bluelagune 9/30/2015 6:26:15 AM(UTC)
Wireless GoPro capture? (General Discussion)
by mikevanveen 3/31/2015 5:36:16 PM(UTC)
GoPro Startup causing high CPU usage (General Discussion)
by Len56 2/25/2015 2:01:54 PM(UTC)
GoPro wireless (General Discussion)
by hogwam 1/27/2015 9:24:58 AM(UTC)
Gopro Cineform HD codec is back ! :) (General Discussion)
by PFBM 1/1/2015 1:28:19 PM(UTC)
New GoPro Cineform HD codec not free anymore..... (General Discussion)
by PFBM 10/16/2014 4:50:32 PM(UTC)
360 Degree GoPro Footage (General Discussion)
by Thremir 8/13/2014 3:54:00 PM(UTC)
UV-map GoPro lens correction (General Discussion)
by doggy 6/23/2014 5:49:54 AM(UTC)
Streaming into vMix Using GoPro Hero 3 (General Discussion)
by davesuemcbride 3/31/2014 12:11:22 AM(UTC)
GoPro media stream (Hardware Compatibility)
by wibwdave 11/12/2013 5:17:23 PM(UTC)
Vmix+Blackmagic Intensity Pro + GoPro Hereo2 - interlacing problem?? (General Discussion)
by vedcom 11/3/2012 8:12:16 AM(UTC)
