Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
I've tried importing a GoPro Hero 3 stream into vMix with success actually.
The footage received however, was not usable at all.
This would be because a GoPro WiFi stream is highly compressed and has lots of delay. This would be because it is not meant to show live high quality footage, but as a low resolution monitor for checking the angle of the camera on the go with a mobile application.
Also, the GoPro unit itself doesn't have the processing power to encode a higher quality video stream.
Hope this answers your question.
Cheers, Håvard
 1 user thanked Thremir for this useful post.
And if you wondered how, that would have been through VLC's streaming feature with the GoPro as input, running a local stream to vMix, adding even more delay...
thanks for the reply... in fact that helps a lot... in that case the easiest way for a goal-cam would be an ip-cam or a GoPro (or any other actioncam) attached to a Teradek Cube/Vidiu.
You have been a member since:: 2/18/2014(UTC) Posts: 1,847 Location: Stockholm
I tried a little with GoPro black, and did not even get a descent video signal via HDMI. Maybe me, googled for a while and it seems that GoPro is best suited for internal recording. Please correct me if I am wrong.
Thanks Håvard, More like a still image than a video ;) But what I saw looked pretty OK.
Can't really remember what kind of issues I had with GoPro HDMI out in to vMix. Might have been stuttering, or pixelation, or something else. I just gave up as it is not important for us at the moment.
Thanks Håvard,
one simple question. The video shown - how did you capture that? Did you send the signal from the GoPro HDMI-Output via cable or via transmitter (f.e. Teradek Cube)? Or was it with the included Wifi-Connection?
Thanks for clearing that up.
Because I don't own a GoPro 3 nor a WiFi backpack for mine (I did the whole GoPro 3 WiFi testing with my friends GoPro), I have to go for the Hero 2's Mini-HDMI output onto my Intensity Pro card in my production PC. (horrible quality) Pics below. https://drive.google.com...sMTRIejg&usp=sharing
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Maybe this is helpfull to you
 1 user thanked instudiomedia for this useful post.
