Beta Discussion
vMix 27 Preview Released!
Joined: 1/13/2010(UTC) Posts: 5,163 Location: Gold Coast, Australia Was thanked: 4176 time(s) in 1499 post(s)
vMix 27.0.0.52 Beta Released!https://cdn.vmix.com/download/vmix27preview.exehttps://www.vmix.com/zoomplugindownloadChanges* Added SoloAllOff shortcut * Solo indicator at top of vMix now indicates for both buses and inputs * Clicking Solo indicator will turn off all Solo * Fixed issue with bus volumes reverting to 0 when changing from a non-audio input to an audio input. * Fixed Layer Designer warning not displaying correctly in some situations * Zoom inputs can now be changed back and forth from different input types. * Updated Zoom SDK to 5.16.10 which now supports receiving Stereo Audio from participants and also receiving isolated share audio when selected. * Desktop Capture now uses WindowsGraphicsCapture method by default when capturing Windows. This has much better performance and ability to capture different applications and also now supports disabling the cursor. * vMix Desktop Capture now supports rotated displays.
12 users thanked admin for this useful post.
QuiapoChurch on 11/23/2023(UTC), richardgatarski on 11/23/2023(UTC), sam602 on 11/23/2023(UTC), eduardocfs on 11/24/2023(UTC), Hitman007 on 11/24/2023(UTC), fgolman on 11/24/2023(UTC), jet on 11/24/2023(UTC), sinc747 on 11/30/2023(UTC), stevespaw on 11/30/2023(UTC), raugert on 12/3/2023(UTC), cody@raceontexas.com on 12/6/2023(UTC), jf_blanco on 12/11/2023(UTC)
vMix 27.0.0.55 Beta Released!https://cdn.vmix.com/download/vmix27preview.exehttps://www.vmix.com/zoomplugindownloadChanges* New Zoom triggers: OnZoomActiveSpeaker OnZoomActiveSpeakerWhileInOutput OnZoomActiveSpeakerSelf See Active Speaker section of this help file page for more information: https://www.vmix.com/help27/ZoomParticipants.html* New shortcuts: SetLayerAnimated, SwapLayerAnimated: These will change a layer, animating the change if possible. ReplayScrollSelectedEvent: To move through replay list using dials such as on the StreamDeck+ * Solo and SendToMaster status now in API for buses * Fix for Input title reverting back when using the API to change the title after previously opening Input settings for the input * Fixed unnecessary scrollbar for icon list in Add Input and Input Settings on 125% scaling monitors. * Fixed error when saving a bundle containing inputs with ' in the filename * Substantially improved performance when using Local Desktop Capture to capture a particular window.
13 users thanked admin for this useful post.
jf_blanco on 12/12/2023(UTC), monamiga on 12/12/2023(UTC), jet on 12/12/2023(UTC), doggy on 12/12/2023(UTC), RichDanby on 12/12/2023(UTC), STADIORADIO on 12/12/2023(UTC), sam602 on 12/13/2023(UTC), Daniel Corro on 12/13/2023(UTC), Soundfloss on 12/13/2023(UTC), Hitman007 on 12/13/2023(UTC), sinc747 on 12/13/2023(UTC), stevespaw on 12/15/2023(UTC), cody@raceontexas.com on 12/15/2023(UTC)
vMix 27.0.0.58 Beta Released!https://cdn.vmix.com/download/vmix27preview.exehttps://www.vmix.com/zoomplugindownloadNotesWe are now close to release, with all known bugs hopefully fixed in this release. If you believe an issue has not been resolved, please post on the Beta Discussion forum or reply to an existing thread on the problem to let us know. Note this does not apply to tweaks or feature requests, as only bug fixes can not be applied. Changes* New Vertical HD 1280 resolution added * Meter Pre-Fader checkbox option added to Audio Settings * NVENC specific presets added to Streaming Quality when Hardware Encoder enabled on an NVENC capable card. These range from P1 to P7 with P4 being similar to the quality set in previous releases by default. * Fix for transition duration exceeding 9999ms applying 500ms instead. Now it will just max out at 9999ms for any values over. * Fix for vMix not detecting the Zoom plugin was installed, when it was first installed while vMix is still running. * Added small delay to GT rendering, to compensate for delays in the GT renderer leading to old or blank frames in the vMix renderer. * Zoom Setup will no longer default to the first meeting in the list, as this may lead to connecting to the wrong meeting unexpectedly when changing the account that is currently logged in on the computer.
16 users thanked admin for this useful post.
jet on 12/30/2023(UTC), jf_blanco on 12/30/2023(UTC), tsioukas on 12/30/2023(UTC), monamiga on 12/30/2023(UTC), Edy Santos on 12/30/2023(UTC), eduardocfs on 12/30/2023(UTC), gpdipalmerahtimur on 12/31/2023(UTC), fgolman on 12/31/2023(UTC), Hitman007 on 12/31/2023(UTC), STADIORADIO on 12/31/2023(UTC), sam602 on 1/1/2024(UTC), spinfold on 1/1/2024(UTC), stevespaw on 1/4/2024(UTC), billpoore on 1/6/2024(UTC), sinc747 on 1/6/2024(UTC), clafarge on 1/14/2024(UTC)
vMix 27.0.0.60 Beta Released!https://cdn.vmix.com/download/vmix27preview.exehttps://www.vmix.com/zoomplugindownloadNotesWe are now close to release, with all known bugs hopefully fixed in this release. If you believe an issue has not been resolved, please post on the Beta Discussion forum or reply to an existing thread on the problem to let us know. Note this does not apply to tweaks or feature requests, as only bug fixes can not be applied. Changes* Fix for borders turning back on when opening Layer Designer * Now shows full Audio input device name in Input Settings * Updated Facebook Stream Key destination with Facebook Settings button to make it clearer on how to find the Facebook Producer web site to configure streams. * Zoom Plugin updated with fix for Mute upon entry meeting setting preventing audio from working.
10 users thanked admin for this useful post.
4 users thanked admin for this useful post.
Beta Discussion
