NDI
DesktopCapture can not be opened...!? on Mac
Downloaded vMixDesktopCapture for Mac. When I try to open it, a message pops ut that
"vMixDesktopCapture is damaged and can not be opened. You should move it to trash." (Translated from Norwegian to English)
I have a MacBookPro (2013 model) with MacOS Sierra 10.12.3. (Updated a small update in MacOS on App Store to see if it helped, but it didn't.) Tried to control-click and open from the meny but got the same result.
Best regards Runar
My earlier version 17.0.0.65 of vMixDesktopCapture works just fine.
Rank:: Advanced Member
Thank you! Used the solution by mkeding, and it worked well. :)
NDI
