RabR
#1 Posted : Thursday, March 30, 2017 1:26:06 AM(UTC)
RabR
Downloaded vMixDesktopCapture for Mac. When I try to open it, a message pops ut that
"vMixDesktopCapture is damaged and can not be opened. You should move it to trash."
(Translated from Norwegian to English)
I have a MacBookPro (2013 model) with MacOS Sierra 10.12.3. (Updated a small update in MacOS on App Store to see if it helped, but it didn't.) Tried to control-click and open from the meny but got the same result.
Best regards
Runar
RabR
#2 Posted : Thursday, March 30, 2017 1:30:47 AM(UTC)
RabR
My earlier version 17.0.0.65 of vMixDesktopCapture works just fine.
ovinas
#3 Posted : Thursday, March 30, 2017 2:08:52 AM(UTC)
ovinas
RabR
#4 Posted : Thursday, March 30, 2017 4:43:45 AM(UTC)
RabR
Thank you!
Used the solution by mkeding, and it worked well. :)
