NDI
DesktopCapture can not be opened...!? on Mac
Downloaded vMixDesktopCapture for Mac. When I try to open it, a message pops ut that
"vMixDesktopCapture is damaged and can not be opened. You should move it to trash." (Translated from Norwegian to English)
I have a MacBookPro (2013 model) with MacOS Sierra 10.12.3. (Updated a small update in MacOS on App Store to see if it helped, but it didn't.) Tried to control-click and open from the meny but got the same result.
Best regards Runar
My earlier version 17.0.0.65 of vMixDesktopCapture works just fine.
Thank you! Used the solution by mkeding, and it worked well. :)
NDI
