jet
#1 Posted : Friday, May 24, 2013 6:53:16 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Hi.
Do Matrox mxo2mini work with vMix 9/10?
If, not would like to get it supported.
Kind regards,
J
Video mixed with vMix (studio portions). Turn subtitles / CC on:
#2 Posted : Saturday, May 25, 2013 12:56:16 AM(UTC)
The web site mentions it has DirectShow compatible drivers so it should work with vMix but has not been tested.
jet
#3 Posted : Saturday, May 25, 2013 3:21:23 AM(UTC)
jet
Hi Martin!
Installed mxo2mini, but not working. vMix says something like this: this device do not support setting frame size in application. Using defaults.
I have set the format correcly in the Matrox util.
All that I get to vMix is the default 640x400, without picture.
Kind regards,
J
jet
#4 Posted : Monday, May 27, 2013 8:37:15 AM(UTC)
jet
jet wrote:
Hi Martin!
Kind regards,
J
It would be nice to be able to use MXO2mini for monitoring.
Kind regards,
Jan
cutter07
#5 Posted : Wednesday, June 5, 2013 7:58:19 PM(UTC)
cutter07
Workaround for the mxo2mini is to use "Adobe Flash Media Live Encoder" to setup the correct format.
After you setup the correct settings for your camara in FMLE you can add it to vMix.
thanks 1 user thanked cutter07 for this useful post.
jet on 6/6/2013(UTC)
jet
#6 Posted : Thursday, June 6, 2013 9:29:05 AM(UTC)
jet
Hi!
Thanks!
I will try this today.
I hope this can be done directly in vMix in the future. I also would like to be able to use mxo2mini for monitoring purposes.
Kind regards,
J. Tervo
Video mixed with vMix 8 (studio portions). Turn subtitles / CC on:
jet
#7 Posted : Friday, June 7, 2013 4:06:16 PM(UTC)
jet
This really worked!
Kind regards,
J. Tervo
wayne
#8 Posted : Thursday, October 17, 2013 4:47:26 PM(UTC)
wayne
Matrox released drivers for vMix support today for the entire MXO2 family and the Mojito MAX card. You can get them here for vMix v11;
http://www.matrox.com/video/en/support/downloads/
Matrox driver version 7.5.1 is the correct drivers
Regards
W@
Guest (7)
