Joined: 11/14/2012(UTC) Posts: 402  Location: Finland Thanks: 260 times Was thanked: 39 time(s) in 37 post(s)
Hi. Do Matrox mxo2mini work with vMix 9/10? If, not would like to get it supported. Kind regards, J
Video mixed with vMix (studio portions). Turn subtitles / CC on:
Joined: 1/13/2010(UTC) Posts: 5,358  Location: Gold Coast, Australia Was thanked: 4765 time(s) in 1636 post(s)
The web site mentions it has DirectShow compatible drivers so it should work with vMix but has not been tested.
Martin vMix
admin wrote:The web site mentions it has DirectShow compatible drivers so it should work with vMix but has not been tested.
Martin vMix Hi Martin! Installed mxo2mini, but not working. vMix says something like this: this device do not support setting frame size in application. Using defaults. I have set the format correcly in the Matrox util. All that I get to vMix is the default 640x400, without picture. Kind regards, J
jet wrote:admin wrote:The web site mentions it has DirectShow compatible drivers so it should work with vMix but has not been tested.
Martin vMix Hi Martin! Installed mxo2mini, but not working. vMix says something like this: this device do not support setting frame size in application. Using defaults. I have set the format correcly in the Matrox util. All that I get to vMix is the default 640x400, without picture. Kind regards, J It would be nice to be able to use MXO2mini for monitoring. Kind regards, Jan
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Workaround for the mxo2mini is to use "Adobe Flash Media Live Encoder" to setup the correct format. After you setup the correct settings for your camara in FMLE you can add it to vMix.
 1 user thanked cutter07 for this useful post.
cutter07 wrote:Workaround for the mxo2mini is to use "Adobe Flash Media Live Encoder" to setup the correct format. After you setup the correct settings for your camara in FMLE you can add it to vMix.
Hi! Thanks! I will try this today. I hope this can be done directly in vMix in the future. I also would like to be able to use mxo2mini for monitoring purposes. Kind regards, J. Tervo - - - - Video mixed with vMix 8 (studio portions). Turn subtitles / CC on:
This really worked! I hope this can be done directly in vMix in the future. Kind regards, J. Tervo
Hello, Matrox released drivers for vMix support today for the entire MXO2 family and the Mojito MAX card. You can get them here for vMix v11; http://www.matrox.com/video/en/support/downloads/Matrox driver version 7.5.1 is the correct drivers Regards W@
