Eliot Hochberg
#1 Posted : Thursday, March 2, 2017 4:03:19 PM(UTC)
Eliot Hochberg
Hi!
I have a long event I will be producing with vMix, and I will need the footage for later to edit and send out.
I know that I can record the individual tracks if I like with the multiple recording options. But can I record to more than one drive the main program? Or can I record the main program in two different formats?
What I'd like to be able to do is record to SD and HD at the same time. I know that for most, SD is no longer useful, but for our client it is. I don't want to have to convert the HD down to SD.
I do have the ability to record out to SD on one of the output channels on a separate device. However, I want redundancy should a drive fail.
Thoughts?
SportsNetUSA.net
#2 Posted : Thursday, March 2, 2017 5:32:39 PM(UTC)
SportsNetUSA.net
Multicorder in 4K and Pro.
thisguy
#3 Posted : Thursday, March 2, 2017 5:50:16 PM(UTC)
thisguy
We use Atomos Ninja / Samurai Blades for redundancy, save locally with vMix and out to Atomos.
Lets us not further tax the system, and get a clean copy of our program out.
I'd say add redundancy to your HD cut, and use that HD to encode down for SD.
AlanZ
#4 Posted : Thursday, March 2, 2017 7:02:44 PM(UTC)
AlanZ
Rank:: Advanced Member
You have been a member since:: 7/11/2015(UTC)
Or is you can get on a network with a second machine running vMix, the first machine can send an NDI output of the program to the second machine which can then record, or stream it.
#5 Posted : Thursday, March 2, 2017 7:51:58 PM(UTC)
Or simply use EXTERNAL out on the same host to feed FFMPEG, VLC or OBS with vMix out to do a 2nd recording.
