Joined: 1/25/2017(UTC) Posts: 39 Location: Los Angeles
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Hi!
I have a long event I will be producing with vMix, and I will need the footage for later to edit and send out.
I know that I can record the individual tracks if I like with the multiple recording options. But can I record to more than one drive the main program? Or can I record the main program in two different formats?
What I'd like to be able to do is record to SD and HD at the same time. I know that for most, SD is no longer useful, but for our client it is. I don't want to have to convert the HD down to SD.
I do have the ability to record out to SD on one of the output channels on a separate device. However, I want redundancy should a drive fail.
Thoughts?
Multicorder in 4K and Pro.
Joined: 10/27/2015(UTC) Posts: 5 Location: Los Angeles
We use Atomos Ninja / Samurai Blades for redundancy, save locally with vMix and out to Atomos. Lets us not further tax the system, and get a clean copy of our program out.
I'd say add redundancy to your HD cut, and use that HD to encode down for SD.
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Or is you can get on a network with a second machine running vMix, the first machine can send an NDI output of the program to the second machine which can then record, or stream it.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Or simply use EXTERNAL out on the same host to feed FFMPEG, VLC or OBS with vMix out to do a 2nd recording.
