Pablo
#1 Posted : Thursday, March 28, 2013 9:58:12 AM(UTC)
Pablo
Hello.
I will buy a high-end nvidia/amd video card. I want to know if i can put for the output, 2 monitors fullscreen. It will be like 1920 x 2160 ( making one monitor total).
This program can support this configuration?
macjaeger
#2 Posted : Thursday, March 28, 2013 2:32:39 PM(UTC)
macjaeger
Do you want to combine both monitors to form one large output area? The problem with that configuration is, that windows would have to treat the two monitors as one single virtual Monitor - i don't think the drivers or windows support that configuration. What do you need the two monitors for? Perhaps a solution like matrox dualhead2go/triplehead2go could achive your goal.
Pablo
#3 Posted : Thursday, March 28, 2013 2:57:00 PM(UTC)
Pablo
I need this to play a Video with that resolution (1920 x 2160) and that's why I will buy the card i mentioned, GeForce 450 (it will use two monitors as if they were only one). I want to know if this software's configuration will support this.
Basically, i have three monitors:
1 - Will be used to run the software
2 & 3 - Will be used to play the video.
Looking forward to your knowledge!
Pablo
ask
#4 Posted : Thursday, March 28, 2013 3:24:07 PM(UTC)
ask
To do what you are asking you need to output to an enternal device that allows you to create a video wall, or use specialised software on your PC. http://en.wikipedia.org/wiki/Video_wall
vMix will output full screen to one monitor not to 2 of 3.Nor can any of the other switching products. It is a limitation of Windows that you cannot spread the windows as you are wanting.
macjaeger
#5 Posted : Thursday, March 28, 2013 6:21:54 PM(UTC)
macjaeger
I agree - you can't do that with this card, or any other desktop card i know of. You could use Matrox DualHead2Go: this is an external box that presents itself to the system as one monitor with super-resolution, takes the images sent to it and distributes them to two or three monitors. But there's a catch: the GeForce 450 won't output 1920 x 2160 anyway, according to nvidias specs it is limited to a maximum resolution of 2560x1600.
Still this scenario makes me wonder about the source of your super sized images? If you have to split the output to two monitors anyway, maybe you could use some other software for that? I've done a panoramic output once, spanning three projectors - used GrandVJ for that.
Pablo
#6 Posted : Thursday, April 4, 2013 9:36:04 AM(UTC)
Pablo
Thanks i'll try to figure what it will be my best option. Any news i'll post here.
Similar Topics
API access to the main MultiView output (Feature Requests)
by dani709 11/5/2026 6:41:53 PM(UTC)
Is SRT output PsF? (SRT)
by KerryDP 11/4/2026 5:08:03 PM(UTC)
API function to set SRT output settings (Feature Requests)
by connor-be 10/15/2026 8:38:28 AM(UTC)
Output Tearing with NVIDIA RTX A1000 (Hardware Compatibility)
by dcarrol2 10/6/2026 2:41:49 PM(UTC)
Call Output Program (Feature Requests)
by mandurphy 9/8/2026 4:23:31 PM(UTC)
Is SRT output in vertical format possible in vMix? (SRT)
by TL68 7/7/2026 6:58:57 PM(UTC)
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
Ability to set specific NDI port for Outputs (Feature Requests)
by jet 6/24/2026 7:39:23 PM(UTC)
Overlay on External Output (General Discussion)
by buntonn 6/19/2026 9:38:59 PM(UTC)
SRT Output Tearing - like an Impressionist painting (SRT)
by nicademus 6/7/2026 9:24:31 AM(UTC)
SRT Output as a Custom Stream Option (SRT)
by nicademus 5/28/2026 2:56:33 PM(UTC)
Audio output from AJA IO X3 is sped up when used with Vmix (General Discussion)
by ejpontius 5/18/2026 7:01:25 AM(UTC)
expand the "Additional Outputs" menu (Feature Requests)
by Alain Lahaye 5/14/2026 1:23:21 AM(UTC)
Multiple output Resolutions - to record Zoom Calls (General Discussion)
by bencodec 4/16/2026 6:59:54 AM(UTC)
Green line at top and bottom when using DeckLink Duo 2 Fill/Key output in vMix (1080i59.94) (Hardware Compatibility)
by ken5o 2/14/2026 8:26:42 PM(UTC)
The ability for Preset Bundles to also save overlay and audio output settings (Feature Requests)
by kuuminsh 2/11/2026 11:10:19 PM(UTC)
fullscreen output NDI (Feature Requests)
by christianb 2/7/2026 8:21:10 AM(UTC)
Copy console output to log file (General Discussion)
by fgolman 2/5/2026 11:09:40 AM(UTC)
NDI HX support for Output (Feature Requests)
by inquattro 2/4/2026 7:20:28 AM(UTC)
Rename Output (NDI)
by MickeyMJJ 2/4/2026 1:49:45 AM(UTC)
help. mic wont work in output C (General Discussion)
by Streampunk 1/16/2026 2:21:54 AM(UTC)
NDI inputs 60 fps, Stream output 29.97 (NDI)
by Juke_Box 12/24/2025 7:58:29 AM(UTC)
NDI Output to Rodecaster Video (NDI)
by fcvideo 12/8/2025 4:29:10 AM(UTC)
Vmix audio output to windows (General Discussion)
by sackboydad 12/8/2025 2:14:02 AM(UTC)
Audio from Camera Input Not Reaching Master Output (Focusrite Interface Setup) (General Discussion)
by mamomo 11/26/2025 9:30:53 PM(UTC)
Output audio channels display (Feature Requests)
by Khutso Matlala 11/26/2025 4:39:44 PM(UTC)
Vmix inputs to be passed straight without busses or outputs (Feature Requests)
by Khutso Matlala 11/26/2025 4:37:45 PM(UTC)
Dedicated output for input as effect (Feature Requests)
by semenov_nick_1990 11/20/2025 7:44:18 PM(UTC)
LUT in Video Sets output. Limitation or Bug? (General Discussion)
by buffos 11/14/2025 9:49:15 PM(UTC)
Can i output 3 stream with rtmp ? (General Discussion)
by raid2001 10/28/2025 4:07:07 AM(UTC)
