guztavo
#1 Posted : Saturday, December 17, 2016 6:05:35 PM(UTC)
guztavo
Hi!
I want to show you the awards streaming. You can see at
The setup:
Video Mixer:
ATEM (working at 1080i50)
Cameras:
3 SONY HXR-MC1500P
1 Panasonic AF100
Streaming:
PC with vMix and graphics streaming at 1080p25 4500kbps and recording same but 6MB
Backup PC
Intercom
4 handys Motorola MR350 for producers
Audio:
Trialcom MXH-601 (http://trialcom.com.ar/producto/mxh-601g-consola-6-canales-celular/) throught line in.
The first 50 minutes the audio comes from our setup, but after that, the audio comes from audio mixer of the event.
This was a issue because i cannot find a proper level, and i dont know how to improve audio quality. You can see the issue at 49:30.
Suggestions will be great!
Regards.
https://drive.google.com...KLC-7-hKYX25zSGtKdjRSMU0
https://drive.google.com...KLC-7-hKYT21CUGZkTHg4NFE
https://drive.google.com...KLC-7-hKYZzdHMURreGx6MFE
https://drive.google.com...KLC-7-hKYWXhMcXJ0a3RMQ2s
https://drive.google.com...KLC-7-hKYTThYR3k1UUotTW8
https://drive.google.com...KLC-7-hKYRFZsLXY4V1pqeDQ
sinc747
#2 Posted : Saturday, December 17, 2016 7:00:50 PM(UTC)
sinc747
Sounds like the audio from the audio mixer of the event was too loud.
- Tom
#3 Posted : Sunday, December 18, 2016 3:26:33 AM(UTC)
@ guztavo
Sounds like a possible impedance mismatch or over modulation situation, but definitely distortion as a result of line output overpowering the line input.
I assume everything sounded fine at the venue, just your Recording/Streaming of it has the issue???
What does the external mixer line out normally feed to, because it is obviously overpowering your vMix audio line in?
(BTW, I loved your graphics!)
Siroki
#4 Posted : Sunday, December 18, 2016 5:42:19 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Nice job!
So you are doing camera switching with ATEM and everything else on vMix?
I am trying to buy and setup the same thing
guztavo
#5 Posted : Sunday, December 18, 2016 5:44:26 PM(UTC)
guztavo
@Tom:
Thanks for answering!
I think the problem was my audio mixer that cannot handle correctly the line input. I found a constant noise (like a blown) when activating the audio input, even without any sound.
Thanks!!
@Ice:
I made a BIG mistake in this event: the control room of the event was installed in the same place (inside the lounge), so when i wanted to listen with headphones, the audio in the lounge was very high and didnt let me listen my headphones, so i was leveling audio looking at the volume leds.
So in the venue was the same issue, but i cant fix it with levels faders.
I always use the external mixer to mix microphones and send them throught line in input of onboard audio card. Always i find noise (like a blown), but wasnt as bad as in this show. The levels in the lounge at the speakers were fine.
About graphics, videohive.net was the first intro (look for "red carpet"). The awards graphics was made by customer, and are very nice!
Thanks!!
@Siroki:
As you said. I found ATEM very nice. The only disadvantage is that you need to fit all inputs at the same resolution.
vMix worked fine with graphics. All the event was at 30/50% CPU usage recording and streaming.
Thanks to all for the advices!
Digitalson
#6 Posted : Tuesday, December 20, 2016 12:37:58 PM(UTC)
Digitalson
Groups:
Well as a audio engineer for live audio,the only to do live bands for video is to have 2 mixes ,one for foh (the audience)and one for the video feed. Cause the foh mix is very different than a mix outside of the PA system ....but anyway very good production!! And the graphics are outstanding!! How did and what did u do them on ? ,I really need great graphics like this ,it's the last step in my productions . But overall very good job ....
guztavo
#7 Posted : Wednesday, December 21, 2016 2:01:26 PM(UTC)
guztavo
Thanks Digitalson for your answer.
I think the audio that i recived was mixed different than what i listened on the event (it's possible that line output has separate mixing options or levels than main mix?). By the way, the mixer that the other company used was a digital one that was handled over a tablet... Amazing (at least for me).
About graphics, the ones with Renault logo was provided by the customer. The other was this one: https://videohive.net/it...carpet/8163827?s_rank=1.
In videohive.net you can find a lot of graphics, professional quality.
One more questions: wich scenario do you think i should have for this kind of events?
Because i think it's a good idea having two mixes, but how do i get that? Double microphones, and all things x2?
Thank you!
Guest (4)
