Showcase
Awards at 1080p25 in Córdoba - Argentina
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
guztavo wrote:The first 50 minutes the audio comes from our setup, but after that, the audio comes from audio mixer of the event. This was a issue because i cannot find a proper level, and i dont know how to improve audio quality. You can see the issue at 49:30. Sounds like the audio from the audio mixer of the event was too loud. - Tom
@ guztavo
Sounds like a possible impedance mismatch or over modulation situation, but definitely distortion as a result of line output overpowering the line input. I assume everything sounded fine at the venue, just your Recording/Streaming of it has the issue??? What does the external mixer line out normally feed to, because it is obviously overpowering your vMix audio line in? (BTW, I loved your graphics!)
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Nice job! So you are doing camera switching with ATEM and everything else on vMix?
I am trying to buy and setup the same thing
@Tom: Thanks for answering! I think the problem was my audio mixer that cannot handle correctly the line input. I found a constant noise (like a blown) when activating the audio input, even without any sound. Thanks!!
@Ice: Thanks for answering! I made a BIG mistake in this event: the control room of the event was installed in the same place (inside the lounge), so when i wanted to listen with headphones, the audio in the lounge was very high and didnt let me listen my headphones, so i was leveling audio looking at the volume leds. So in the venue was the same issue, but i cant fix it with levels faders. I always use the external mixer to mix microphones and send them throught line in input of onboard audio card. Always i find noise (like a blown), but wasnt as bad as in this show. The levels in the lounge at the speakers were fine. About graphics, videohive.net was the first intro (look for "red carpet"). The awards graphics was made by customer, and are very nice! Thanks!!
@Siroki: Thanks for answering! As you said. I found ATEM very nice. The only disadvantage is that you need to fit all inputs at the same resolution. vMix worked fine with graphics. All the event was at 30/50% CPU usage recording and streaming.
Thanks to all for the advices!
Groups: Guests
Well as a audio engineer for live audio,the only to do live bands for video is to have 2 mixes ,one for foh (the audience)and one for the video feed. Cause the foh mix is very different than a mix outside of the PA system ....but anyway very good production!! And the graphics are outstanding!! How did and what did u do them on ? ,I really need great graphics like this ,it's the last step in my productions . But overall very good job ....
Digitalson wrote:Well as a audio engineer for live audio,the only to do live bands for video is to have 2 mixes ,one for foh (the audience)and one for the video feed. Cause the foh mix is very different than a mix outside of the PA system ....but anyway very good production!! And the graphics are outstanding!! How did and what did u do them on ? ,I really need great graphics like this ,it's the last step in my productions . But overall very good job .... Thanks Digitalson for your answer. I think the audio that i recived was mixed different than what i listened on the event (it's possible that line output has separate mixing options or levels than main mix?). By the way, the mixer that the other company used was a digital one that was handled over a tablet... Amazing (at least for me). About graphics, the ones with Renault logo was provided by the customer. The other was this one: https://videohive.net/it...carpet/8163827?s_rank=1.In videohive.net you can find a lot of graphics, professional quality. One more questions: wich scenario do you think i should have for this kind of events? Because i think it's a good idea having two mixes, but how do i get that? Double microphones, and all things x2? Thank you!
Showcase
