tony marone
#1 Posted : Friday, February 8, 2013 8:49:57 PM(UTC)
tony marone
Hi Martin,
I have recently started using shortcuts and the web interface. This is a very cool feature! I was wondering what your thinking is on a few issues I have with shortcuts.
First, I discovered that shortcuts are saved in the config file. It would save work if they were added to the preset file. That way they could be moved to another machine without having to re-enter everything. What do you think?
Second, the amount of text on the keys in some cases can be unnecessary. The type of transition and the target of the transition which are the second and third line could be each toggled with a check box, I think. This would make for less clutter on the web interface.
Third, what do you think of the ability to set each button color independently?
Here is my usage scenario:
I am using vMix to play back multiple stills and/or videos to feed a big projector. The operator was using just the laptop with vMix originally but had the typical problems of laptop mouse uncertainty. I discovered the web interface and using it on an iPad and things got much better! I am just trying to make the interface less cluttered and easier to set up. We will usually edit the videos and stills on a machine in the studio and then test everything in vMix and finally build the shortcuts. All of our elements and the preset file are stored in Dropbox on that machine. Everything syncs to the laptop which is used at the show. If the preset also contained the shortcuts, it would be quite seamless.
We just did our biggest show of the year last Saturday! vMix was used once again to play back all stills and video to a Panasonic 22,000 lumen projector onto an 32' x 18' screen.
Karen, the operator, thanks you immensely for the FTB button that we asked for last year!!
I hope you will take my ideas into consideration and let me know what you think.
Tony
Similar Topics
Merging Scripts and Shortcuts (only) (General Discussion)
by vjmandala 12/3/2024 3:04:04 PM(UTC)
Web Controller - shortcuts (Feature Requests)
by vjmandala 11/27/2024 9:02:41 AM(UTC)
Multiple Shortcuts in one press (Feature Requests)
by vjmandala 11/27/2024 8:59:38 AM(UTC)
overlay channels shortcuts-same input between mix inputs (Beta Discussion)
by nikosman88 11/22/2024 11:41:33 PM(UTC)
Shortcuts for Midi to control of all/any sliders (Feature Requests)
by vjmandala 11/14/2024 11:46:06 AM(UTC)
VMix shortcuts - sliders (General Discussion)
by vjmandala 11/13/2024 2:24:15 PM(UTC)
Add Split Audio Controls via Shortcuts along with Mono Sum (Feature Requests)
by offroadmediagroup 11/6/2024 3:49:33 AM(UTC)
"Shortcuts only" sringers/overlays on sub mixes (General Discussion)
by spinfold 10/12/2024 10:25:38 PM(UTC)
Identify or sort shortcuts by shortkey (Feature Requests)
by Salleman 10/2/2024 7:00:01 PM(UTC)
Streamdeck Shortcuts disappeared (General Discussion)
by Johann973 9/30/2024 9:35:41 AM(UTC)
Shortcuts to change output multiview slots (Feature Requests)
by WaltG12 9/21/2024 5:17:00 AM(UTC)
Channel Mixer shortcuts (General Discussion)
by mark 8/31/2024 12:25:31 PM(UTC)
VMix call remote shortcuts (Feature Requests)
by DJShaggyd 8/20/2024 9:42:55 PM(UTC)
Shortcuts to adjust Text Font Size (e.g. for use as a teleprompter) (Feature Requests)
by richardgatarski 7/19/2024 6:40:57 AM(UTC)
Instant replay "jump to" shortcuts (Feature Requests)
by doggy 5/22/2024 4:15:07 AM(UTC)
Shortcuts for List Ordering (Feature Requests)
by leotiago 5/21/2024 6:49:28 AM(UTC)
Duplicated Shortcuts (General Discussion)
by shampton 4/11/2024 3:31:42 AM(UTC)
VMIX Shortcuts - Companion / StreamDeck (General Discussion)
by bounce 1/20/2024 4:10:53 AM(UTC)
Question about ways calling inputs via shortcuts, api:s etc (General Discussion)
by TL68 1/4/2024 6:29:34 PM(UTC)
Triggers to activate /de-activate key shortcuts (Feature Requests)
by sdonn 1/4/2024 3:14:28 AM(UTC)
Desktop Capture Shortcuts (Feature Requests)
by jsjoen7896 12/20/2023 2:34:11 PM(UTC)
Shortcuts for Triggers (Feature Requests)
by Edy Santos 11/21/2023 10:39:47 PM(UTC)
Over 150 New Shortcuts – Can We Get A List? (Beta Discussion)
by kmedia 11/18/2023 2:34:15 AM(UTC)
Demo: 'zoom around' in an input by utilizing the new shortcuts (Beta Discussion)
by furtive 11/10/2023 8:10:59 AM(UTC)
Images Assigned to Shortcuts (General Discussion)
by Hank 11/8/2023 3:53:38 AM(UTC)
Shortcuts Companion Streamdeck + vMix for Intsant Replay (Instant Replay)
by Aurios 10/27/2023 11:41:07 PM(UTC)
Shortcuts Companion + vMix for Instant Replay (3rd Party Software and Development)
by Aurios 10/27/2023 11:33:58 PM(UTC)
Please add shortcuts to control overlay size, cropping and position. (Beta Discussion)
by AlanZ 10/26/2023 5:04:46 AM(UTC)
Shortcuts don't always work (General Discussion)
by DougF 9/11/2023 1:15:04 AM(UTC)
DVD Inputs Shortcuts (Feature Requests)
by RichShumaker 9/7/2023 5:32:03 AM(UTC)
