Hi, I need a capture card SDI with at least two inputs and one output, something cheap, you can give me some suggestions? thank you
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
op music wrote:this card has 2 inputs and 2 outputs? I can use it with WMIX to enter and exit? Decklink Duo 2 has 4 SDI connections, you can assign as you want. You can make: - 4 inputs, 0 outputs - 3 inputs, 1 output - 2 inputs, 2 outputs - 1 input, 3 outputs - 0 input, 4 outputs (vMix Basic, SD and HD have only one external output while vMix 4K and PRO have 2 external outputs) No. You need Decklink Duo 2 - that is 2nd generation of old Decklink Duo. Old Decklink Duo has 2 inputs and 2 pass through outputs.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Duo 2 is the best option but you could get the Duo 1 and a DL Mini monitor for the output, or two used Duo 1 or a used DL Quad.
