op music
#1 Posted : Friday, November 11, 2016 9:05:45 AM(UTC)
op music
Hi, I need a capture card SDI with at least two inputs and one output, something cheap, you can give me some suggestions? thank you
#2 Posted : Friday, November 11, 2016 9:47:40 AM(UTC)
@ op music
What's your definition of "cheap"?
At the moment, I believe the BMD Decklink Duo 2 is the best bang for the buck with 4 I/O at just under $500US
https://www.bhphotovideo...mp;A=details&pcur=US
But be AWARE there are still some original Decklink Duo's out there around the same price point that are ONLY 2 I/O.
https://www.amazon.com/g...e=UTF8&condition=all
op music
#3 Posted : Friday, November 11, 2016 12:33:50 PM(UTC)
op music
Thanks for giving me ice responded, this card has 2 inputs and 2 outputs? I can use it with WMIX to enter and exit? I found this okay? http://www.ebay.it/itm/D...fab10:g:oG8AAOSwaB5XuJON thanks
r@wisla
#4 Posted : Friday, November 11, 2016 1:07:53 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Decklink Duo 2 has 4 SDI connections, you can assign as you want.
You can make:
- 4 inputs, 0 outputs
- 3 inputs, 1 output
- 2 inputs, 2 outputs
- 1 input, 3 outputs
- 0 input, 4 outputs
(vMix Basic, SD and HD have only one external output while vMix 4K and PRO have 2 external outputs)
op music wrote:
No. You need Decklink Duo 2 - that is 2nd generation of old Decklink Duo. Old Decklink Duo has 2 inputs and 2 pass through outputs.
op music
#5 Posted : Friday, November 11, 2016 1:24:17 PM(UTC)
op music
thank
Peter B
#6 Posted : Saturday, November 12, 2016 4:18:07 PM(UTC)
Peter B
Duo 2 is the best option but you could get the Duo 1 and a
DL Mini monitor for the output, or two used Duo 1 or a used DL
Quad.
