Charssay
#1 Posted : Thursday, January 17, 2013 7:07:44 AM(UTC)
Charssay
Dear All
is that Possible VMIX do a transparency with two video at the same time
I mean, if the overlay done with one Video on another let the first one present on the screen like a transparency
I don't know if my explanation is more clear
C.
mmorlan62
#2 Posted : Wednesday, January 23, 2013 6:45:03 PM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
Hi Charssay,
I understand you. I've just begun to play with VMix and have successfully overlaid a video with alpha transparency over the program video. To do so, I;
o created an RGB-Alpha Quicktime file
o imported that file as an input
o clicked the [1] Overlay button under the that input to overlay the graphic over the program output (similar to a downstream keyer.)
-or-
o import that file as an input
o included it as a Multi View layer in another input (thus overlaying it with the background)
o transitioned the multi-layer input into the program output
Best,
Michael
Charssay
#3 Posted : Thursday, January 24, 2013 4:24:32 AM(UTC)
Charssay
Dear Michael
I Will try. But the goal is to do that with live input video also
Rgds
Charssay
Similar Topics
uv-mapping artifacts when transparency is involved (General Discussion)
by buffos 1/13/2026 6:12:54 PM(UTC)
Allow for transparency on shapes filled with gradients (Feature Requests)
by offroadmediagroup 4/9/2025 8:21:22 AM(UTC)
Website Transparency not Working in vMix but does in OBS (General Discussion)
by tanowalla 8/21/2022 3:11:57 PM(UTC)
application capture, allow transparency option missing (General Discussion)
by FlinSavage 5/10/2022 8:32:44 PM(UTC)
NDI 4.0 Transparency Recording (NDI)
by doggy 9/14/2019 7:53:52 PM(UTC)
GPU Memory VS GPU Cache - - transparency and information? (General Discussion)
by Jeremy G 6/22/2019 2:14:15 PM(UTC)
Flash Transparency different behaviour on 2 systems (Hardware Compatibility)
by kgoodyer 9/9/2015 9:13:03 AM(UTC)
mov-videofile withs transparency not working on 64bit (General Discussion)
by DeeJay 12/19/2013 6:24:26 PM(UTC)
Feature request - Transparency and resizing of audio mixer window (General Discussion)
by ClementN 6/6/2012 2:27:39 AM(UTC)
Video transparency in vMix (General Discussion)
by maximronkin 1/3/2012 1:06:25 PM(UTC)
