Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Dear All
is that Possible VMIX do a transparency with two video at the same time
I mean, if the overlay done with one Video on another let the first one present on the screen like a transparency
I don't know if my explanation is more clear
C.
Joined: 1/23/2013(UTC) Posts: 65  Thanks: 3 times Was thanked: 7 time(s) in 5 post(s)
Hi Charssay,
I understand you. I've just begun to play with VMix and have successfully overlaid a video with alpha transparency over the program video. To do so, I;
o created an RGB-Alpha Quicktime file o imported that file as an input o clicked the [1] Overlay button under the that input to overlay the graphic over the program output (similar to a downstream keyer.)
-or-
o import that file as an input o included it as a Multi View layer in another input (thus overlaying it with the background) o transitioned the multi-layer input into the program output
Best,
Michael
Dear Michael
Thanks I Will try. But the goal is to do that with live input video also
Rgds
Charssay
