#1 Posted : Saturday, July 30, 2016 8:50:32 AM(UTC)
from remote computer no problem, local desktop just black
NVidia Geforce GTX960M (selectable per application)
Guy
#2 Posted : Saturday, July 30, 2016 9:21:07 AM(UTC)
You have been a member since:: 1/13/2010(UTC)
Was thanked: 4692 time(s) in 1611 post(s)
If you are using a laptop running Optimus, if you select Add Input -> NDI and select Local Desktop Capture you can capture the entire display
easily enough, but if a particular application is only displaying blank, then it is because it is using different graphics so you will need to
run that application with GTX960M as well.
#3 Posted : Saturday, July 30, 2016 9:54:07 AM(UTC)
Tried that Martin , sorry no dice
#4 Posted : Saturday, July 30, 2016 10:22:42 AM(UTC)
Then it means that particular application doesn't support hidden or direct window capture and only capturing the entire display will be possible.
#5 Posted : Saturday, July 30, 2016 10:40:49 AM(UTC)
Not one application
Using integrated GPU no problem whatsoever
Guest (6)
