What is the trick to get local desktop capture working ?
from remote computer no problem, local desktop just black
NVidia Geforce GTX960M (selectable per application)
Guy
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
If you are using a laptop running Optimus, if you select Add Input -> NDI and select Local Desktop Capture you can capture the entire display easily enough, but if a particular application is only displaying blank, then it is because it is using different graphics so you will need to run that application with GTX960M as well.
Martin vMix
Tried that Martin , sorry no dice
Then it means that particular application doesn't support hidden or direct window capture and only capturing the entire display will be possible.
Martin vMix
Not one application
Using integrated GPU no problem whatsoever
