What is the trick to get local desktop capture working ?
You have been a member since:: 12/27/2012(UTC) Posts: 5,507  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
from remote computer no problem, local desktop just black
NVidia Geforce GTX960M (selectable per application)
Guy
Rank:: Administration
Joined: 1/13/2010(UTC) Posts: 5,308  Location: Gold Coast, Australia Was thanked: 4692 time(s) in 1611 post(s)
If you are using a laptop running Optimus, if you select Add Input -> NDI and select Local Desktop Capture you can capture the entire display easily enough, but if a particular application is only displaying blank, then it is because it is using different graphics so you will need to run that application with GTX960M as well.
Martin vMix
Tried that Martin , sorry no dice
Then it means that particular application doesn't support hidden or direct window capture and only capturing the entire display will be possible.
Martin vMix
Not one application
Using integrated GPU no problem whatsoever
