Thanks: 1 times Was thanked: 5 time(s) in 3 post(s)
Hello What kind of HD security camera can i use for my fixed chroma studio
i used 5D mark II , with separate audio input , but i always have audio latacy
thanks a lot
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Using a 5D Mark II should be fine, how do you input the signal from the camera to vMix?
You should be able to use any decent quality camera paired with a capture card.
