ichn1
#1 Posted : Tuesday, July 26, 2016 4:28:28 PM(UTC)
ichn1
Hello
What kind of HD security camera can i use for my fixed chroma studio
i used 5D mark II , with separate audio input , but i always have audio latacy
thanks a lot
Lennart
#2 Posted : Thursday, July 28, 2016 8:46:07 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
Using a 5D Mark II should be fine, how do you input the signal from the camera to vMix?
You should be able to use any decent quality camera paired with a capture card.
