toniX
#1 Posted : Saturday, January 5, 2013 7:21:34 PM(UTC)
toniX
hello,
I need technical support.
I have just downladed the software, I have installed it but,a problem to unlock either, the basic and the 60 days trial softaware.
I insert my email address in the field, as requested but then, I receive an error message in a black box ,like this:
(Exception fom HRESULT:0x80040154(regdb_E_CLSSNOTERG))
Furthemore this black box shows two options: 1)send report, 2)close,
clicking chioce #1 cause looping the eror message, clicking choice #2 cause
go back the registation form!!!
Quite odd, isn't?
Do you know how to solve this issue?
I would like to give a try to you software.
Thanks for help.
Happy New Year all.
#2 Posted : Saturday, January 5, 2013 9:32:14 PM(UTC)
Unfortunately this error means that your Windows installation is corrupt.
You will need to re-install windows to fix this error.
