Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Nick, have you tried turning off the firewall on the Macbook? http://www.wikihow.com/Turn-off-Mac-FirewallThese symptoms are usually firewall or CPU version related. From the specs of you machine I suspect the former. Andrew
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Thanks to all those that have submitted reports so far. Below you will find version 17.0.0.64 of the vMix Desktop Capture for Windows NDI app with the following bug fixes: * Was not detecting windows on Windows 7 machines with DWM (Aero) disabled * Fixed errors on multi monitor machines where the layout of the displays is not sequential. (2 before 1 for example) http://www.vmix.com/down...MixDesktopCaptureNDI.zipRegards, Martin vMix
Thanks for the update Martin! Wish it had arrived 24 hours earlier, I was struggling yesterday on a laptop that had it's external display (2) positioned above the built in display (1).
In any case, it works perfect now.
ask wrote:Nick, have you tried turning off the firewall on the Macbook? http://www.wikihow.com/Turn-off-Mac-FirewallThese symptoms are usually firewall or CPU version related. From the specs of you machine I suspect the former. Andrew Nick Davidson attached the following image(s):  Screen Shot 2016-05-03 at 4.09.37 PM.png (54kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Same issue :( Would be great to resolve this before the race on Saturday Missing my desktop capture... Nick Davidson attached the following image(s):  NDI black nada.png (31kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Short term solution for Saturday. Bring the Laptop in as a camera input via HDMI. Next, I assume that there is a NDI Scan Convertor and NDI Monitor for Mac. Kane from Newtek (send hin a PM if he doesn't respond to this post) may be able to help with where to find them (I was not able to see a link on the Newtek site). Load them and confirm that you are getting visible NDI source on that machine.
Meantime, Martin may have some other ideas.
Rank:: Advanced Member
Groups:: Registered
ask wrote:Short term solution for Saturday. Bring the Laptop in as a camera input via HDMI. Next, I assume that there is a NDI Scan Convertor and NDI Monitor for Mac. Kane from Newtek (send hin a PM if he doesn't respond to this post) may be able to help with where to find them (I was not able to see a link on the Newtek site). Load them and confirm that you are getting visible NDI source on that machine.
Meantime, Martin may have some other ideas. Sienna makes a free and paid (+ feature rich) NDI Scan Converter for Macintosh. You can find them both in the OSX App Store. There currently isn't a NDI Monitor for OSX at this point. NewTek Connect Pro does include a web server that allows a web browser to see multiple NDI sources, might be a solution for the time being. Kane Peterson NewTek
Groups:: Registered
Nick Davidson wrote:Same issue :( Would be great to resolve this before the race on Saturday
Have you tried another network cable? Someone I know had a substandard CAT5 cable and was getting results similar to what you have. It would see the 'connections' but only be black in the video windows. The network cable he was using was corrupting so many packets that no video could get through. Kane Peterson NewTek
kane wrote: Have you tried another network cable? Someone I know had a substandard CAT5 cable and was getting results similar to what you have. It would see the 'connections' but only be black in the video windows. The network cable he was using was corrupting so many packets that no video could get through.
Good point Kane. Nick, try connecting the two computers directly with a crossover cable rather than using a router/switch. You will need to assign IP addresses, mask and gateway. That will ensure the router/switch is not degrading the signal on the way through.
ask wrote:kane wrote: Have you tried another network cable? Someone I know had a substandard CAT5 cable and was getting results similar to what you have. It would see the 'connections' but only be black in the video windows. The network cable he was using was corrupting so many packets that no video could get through.
Good point Kane. Nick, try connecting the two computers directly with a crossover cable rather than using a router/switch. You will need to assign IP addresses, mask and gateway. That will ensure the router/switch is not degrading the signal on the way through. You don't need crossover cable in most new Network cards As per my post last week. Using your second NIC for NDI with crossover or standard network cable to a laptopbecause of Auto_MDI-X
Understand that James. A crossover cable is a safe option though if you don't know if the NICs are auto-sensing.
I have Desktop Capture working on the Mac Book. I hate to admit my ignorance but it was simply a wrong ip Address set on the Mac Book, an updated iP address and it worked!
Please forgive me for my ignorance. I've never been the best at setting up networks but I'm learning fast.
