DigitalDaz
#1 Posted : Monday, April 11, 2016 7:22:29 PM(UTC)
Rank: Guest
Groups:
What should I be recording NDI at bitrate wise?
I'm just testing VMIX, I usually use Ingex and capture at 185Mbit VC-3
I see no point in recording at these high bitrates if the NDI input is much lower.
TIA
Daz
ask
#2 Posted : Monday, April 11, 2016 8:56:44 PM(UTC)
ask
NDI uses a variable bit rate. Do a search on these forums and you will find a note from Newtek explaining it.
