Rank: Guest
Groups: Guests
What should I be recording NDI at bitrate wise?
I'm just testing VMIX, I usually use Ingex and capture at 185Mbit VC-3
I see no point in recording at these high bitrates if the NDI input is much lower.
TIA
Daz
NDI uses a variable bit rate. Do a search on these forums and you will find a note from Newtek explaining it.
