To Tick the 'Hardware Encoder' or not
Joined: 1/19/2016(UTC) Posts: 6   Location: London Thanks: 5 times
Can you tell me what ticking the "use Hardware Encoder (BETA)" will actually do. Not sure how it works with V 16.115.
Rod L
It will use the videocard instead of the cpu for the encoding. In vmix 17 it's out of beta and it helps a lot keeping cpu usage down, which can be used for other things.
 1 user thanked Mathijs for this useful post.
