rodlucas
#1 Posted : Wednesday, March 23, 2016 12:46:24 PM(UTC)
rodlucas
Can you tell me what ticking the "use Hardware Encoder (BETA)" will actually do. Not sure how it works with V 16.115.
Rod L
Mathijs
#2 Posted : Wednesday, March 23, 2016 8:56:04 PM(UTC)
Mathijs
It will use the videocard instead of the cpu for the encoding. In vmix 17 it's out of beta and it helps a lot keeping cpu usage down, which can be used for other things.
thanks 1 user thanked Mathijs for this useful post.
rodlucas on 3/24/2016(UTC)
