Multiple different rtmp destinations
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
I would like to send out one stream to 2 different CDNs. I know I can do it through the Advanced tab, say to YouTube (primary and backup), but can it work with, say Dacast and YouTube (or any 2 different CDNs)? Has anyone done this? I would assume you could if you didnt enter the destination presets but used default. The destination presets turn off the Advanced tab. Well, I will try it....
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
vMix can simulcast to multiple destinations, Just click the [1-4] buttons in the stream settings.
jhebbel wrote:the [1-4] buttons ? - not clear....
Open your stream settings, do you see buttons labeled 1-4? click them.
no I do not using 16 0 0 115 & 114
I have no numbered settings, only Destination URL Key or Name, and Advanced, which has 2 entry spots, one for name and password, and the other for URL, UN & PW.
FIXED: NOTE: APPLICATION needs to be set to FFMPEG, not FMLE !
Hmm, i never noticed that FMLE did not support multicast. If you must use FMLE you can try setting up a RTMP bounce using Unreal Media Server or ngix.
as regards the FMLE vs FFMPEG encode: could someone explain the difference in the log reports to me? Viewing status in FMLE shows a simple "chart" where FFMPEG shows an updating frame/fps/kbps/sec report. Is that normal, and does it build a huge log file over time (and can I discard it)? Thanks
Joined: 12/19/2013(UTC) Posts: 600   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
use www.restream.io, Youtube and all big websites are free to stream to, if you need custom cdn's, you pay 15 $ per destination. The positive side of this, is that you use less bandwidth on location.
