HWL1223
#1 Posted : Thursday, January 28, 2016 6:22:19 PM(UTC)
HWL1223
I would like to send out one stream to 2 different CDNs. I know I can do it through the Advanced tab, say to YouTube (primary and backup), but can it work with, say Dacast and YouTube (or any 2 different CDNs)?
Has anyone done this? I would assume you could if you didnt enter the destination presets but used default. The destination presets turn off the Advanced tab.
Well, I will try it....
jhebbel
#2 Posted : Thursday, January 28, 2016 7:03:24 PM(UTC)
jhebbel
vMix can simulcast to multiple destinations, Just click the [1-4] buttons in the stream settings.
HWL1223
#3 Posted : Thursday, January 28, 2016 7:08:35 PM(UTC)
HWL1223
jhebbel wrote:
the [1-4] buttons
? - not clear....
jhebbel
#4 Posted : Thursday, January 28, 2016 7:10:36 PM(UTC)
jhebbel
Open your stream settings, do you see buttons labeled 1-4? click them.
HWL1223
#5 Posted : Thursday, January 28, 2016 7:19:37 PM(UTC)
HWL1223
no I do not
using 16 0 0 115 & 114
I have no numbered settings, only
Destination
URL
Key or Name,
and
Advanced, which has 2 entry spots, one for name and password, and the other for URL, UN & PW.
FIXED:
NOTE: APPLICATION needs to be set to FFMPEG, not FMLE !
jhebbel
#6 Posted : Friday, January 29, 2016 8:01:33 AM(UTC)
jhebbel
Hmm, i never noticed that FMLE did not support multicast. If you must use FMLE you can try setting up a RTMP bounce using Unreal Media Server or ngix.
HWL1223
#7 Posted : Friday, January 29, 2016 12:58:42 PM(UTC)
HWL1223
as regards the FMLE vs FFMPEG encode: could someone explain the difference in the log reports to me?
Viewing status in FMLE shows a simple "chart" where FFMPEG shows an updating frame/fps/kbps/sec report.
Is that normal, and does it build a huge log file over time (and can I discard it)?
Ittaidv
#8 Posted : Friday, January 29, 2016 4:23:31 PM(UTC)
Ittaidv
Views messages in topic : 602
use www.restream.io, Youtube and all big websites are free to stream to, if you need custom cdn's, you pay 15 $ per destination. The positive side of this, is that you use less bandwidth on location.
