tesn
#1 Posted : Saturday, January 16, 2016 9:31:35 AM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
I'm not 100% sure if I can't do this already or not, but I'd like to be able to set a virtual set's layer source using shortcuts/API.
We use a couple virtual sets for our sports productions, where we basically do a split screen, or live lookin at another game. I would love to be able to set the layer source using a shortcut.
Something like ?SetLayerSource&Layer=Right&Input=Camera1
Does that make sense?
-Brian
#2 Posted : Saturday, January 16, 2016 10:09:44 AM(UTC)
Haven't found a direct shortcut but an indirect one.
- add a colorinput
- set it's multiview 1 to one of your videoinputs
- create shortcut SetMultiViewOverlay to switch the multiviewlayer to another videoinput
- create shortcut SetMultiViewOverlay to switch the multivielayer (back) to your first videoinput ( and so on)
- specify your virtualsetlayer to your colorinput
now you can switch with the video's in your virtualset with your shortcuts ( or through API calls)
if there is a direct one then discard this reply
#3 Posted : Saturday, January 16, 2016 10:14:06 AM(UTC)
@ tesn
Have you tried "SetMultiViewOverlay"?
http://www.vmix.com/help...utFunctionReference.html
Virtual Sets are essentially "MultiViews", you'll just have to identify which layer is which for your "Index" value.
tesn
#4 Posted : Saturday, January 16, 2016 10:38:07 AM(UTC)
tesn
IceStream wrote:
@ tesn
That's the one. Thanks! I thought I might be able to already. Just couldn't find it.
-Brian
