Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
I'm not 100% sure if I can't do this already or not, but I'd like to be able to set a virtual set's layer source using shortcuts/API.
We use a couple virtual sets for our sports productions, where we basically do a split screen, or live lookin at another game. I would love to be able to set the layer source using a shortcut.
Something like ?SetLayerSource&Layer=Right&Input=Camera1
Does that make sense?
-Brian
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Haven't found a direct shortcut but an indirect one.
- add a colorinput - set it's multiview 1 to one of your videoinputs - create shortcut SetMultiViewOverlay to switch the multiviewlayer to another videoinput - create shortcut SetMultiViewOverlay to switch the multivielayer (back) to your first videoinput ( and so on) - specify your virtualsetlayer to your colorinput
now you can switch with the video's in your virtualset with your shortcuts ( or through API calls)
if there is a direct one then discard this reply
That's the one. Thanks! I thought I might be able to already. Just couldn't find it. -Brian
