how many desktop capture inputs?
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
just wondering, before i start to test it: just how many desktop capture inputs can be used before things get messy? anybody tried it? Martin: is there some maximum or limitation?
greetings, stefan
h2video.nl wrote:just wondering, before i start to test it: just how many desktop capture inputs can be used before things get messy? anybody tried it? Martin: is there some maximum or limitation?
greetings, stefan I used to take the same input (single machine being captured) about 4 times then it got laggy/less reliable. It ran ok with 6 before it started saying "error", but with 4 it was still fast. Now I just create a virtual input from the master input :) This was before I discovered create virtual input. As for how many can be taken in from different computers well I'm not sure, but I take 8+ FULLHD cameras in no problems, so can't see why it would be harder than that for the computer. So to guess I'd say 10+ would be a non-issue. How many do you have in mind?
I think it depends, to a certain extent, on the capacity of your system and/or video card. I've never really tested it, and don't use it that often but I seem to run into issues if I try to add more than 2 instances from the same computer. (GeForce GTX 470, dual screen)
