h2video.nl
#1 Posted : Sunday, October 11, 2015 4:29:44 PM(UTC)
h2video.nl
just wondering, before i start to test it: just how many desktop capture inputs can be used before things get messy? anybody tried it? Martin: is there some maximum or limitation?
greetings,
stefan
Speegs
#2 Posted : Monday, October 12, 2015 1:55:04 AM(UTC)
Speegs
greetings,
stefan
I used to take the same input (single machine being captured) about 4 times then it got laggy/less reliable. It ran ok with 6 before it started saying "error", but with 4 it was still fast.
Now I just create a virtual input from the master input :) This was before I discovered create virtual input.
As for how many can be taken in from different computers well I'm not sure, but I take 8+ FULLHD cameras in no problems, so can't see why it would be harder than that for the computer.
So to guess I'd say 10+ would be a non-issue. How many do you have in mind?
#3 Posted : Monday, October 12, 2015 9:52:02 AM(UTC)
I think it depends, to a certain extent, on the capacity of your system and/or video card.
I've never really tested it, and don't use it that often but I seem to run into issues if I try to add more than 2 instances from the same computer.
(GeForce GTX 470, dual screen)
GeorgeR on 10/12/2015(UTC)
