meen1230
#1 Posted : Sunday, September 27, 2015 11:34:37 AM(UTC)
meen1230
I'm trying to make live stream using vmix , but I'm receiving the above error " Capture Resolutioin is not Supported by this Device"
I use Wintv-PVR-500 Pci capture card And It's doesn't work??
Vmix Show me this Text
"AddNewInput.The following are supported:
720x576 PAL 50i or 25p HCW2
Unspecified error "
Any help would be appreciated.
meen1230 attached the following image(s):
#2 Posted : Sunday, September 27, 2015 11:02:55 PM(UTC)
@ meen1230
"Flashback" or what?
vMix 12, Windows XP, PCI...
No wait, what year is it, 2558?
Oh the 'good old days' of the future, lol.
But seriously, what are you trying to capture?
It would appear that your Hauppauge WinTV-PVR-500 is PAL based and only supports the 720x576 PAL 50i SD resolution, anything else will likely return that error message.
(if you move that 'Error' message window out of the way, we will likely see what the issue might be).
meen1230
#3 Posted : Sunday, September 27, 2015 11:50:25 PM(UTC)
meen1230
IceStream wrote:
@ meen1230
Thanks for feedback me Ice.
And yes it's Windows XP PCI CARD LOL
I just want to make live stream using my camera and capture by this PCI Card And live stream using Vmix 12
I've try to use advice resolution from error that message. 720 x 576
I've try another capture program and it's work But it's still not working Vmix.. T_T
Vmix Error.png (66kb) downloaded 1 time(s).
#4 Posted : Monday, September 28, 2015 12:05:21 AM(UTC)
@ meen1230
What happens if you set the "Frame Rate" to 50i or 25p?
I can only assume your camera is also PAL 720x576 50i and/or 25p??? (what make and model is your camera?)
Also, what "other" capture program are you referring to where it works?
(Hauppauge proprietary program perhaps???, sometimes their hardware is only designed to work with 'their' software).
hellokitty
#5 Posted : Monday, September 28, 2015 2:30:45 AM(UTC)
hellokitty
thats vmix trial version 12? what the? and XP? you need to step it up a notch, i think support ended a long time ago. and your running a crack i bet.
meen1230
#6 Posted : Monday, September 28, 2015 3:31:16 AM(UTC)
meen1230
No i'm not using crack I have Vmix 12 Installation just use TRIAL Version 60 days
And it's not windows XP It's windows 7 that theme just look like XP.
Similar Topics
Capture Resolutioin is not Supported by this Device (General Discussion)
by cubalibre 10/17/2011 10:08:56 AM(UTC)
