Capture Resolutioin is not Supported by this Device
Hello, I'm trying to make live stream using vmix , but I'm receiving the above error " Capture Resolutioin is not Supported by this Device" I use Wintv-PVR-500 Pci capture card And It's doesn't work?? Vmix Show me this Text "AddNewInput.The following are supported: 720x576 PAL 50i or 25p HCW2 Unspecified error " Any help would be appreciated. meen1230 attached the following image(s):  1235.png (112kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
@ meen1230
"Flashback" or what? vMix 12, Windows XP, PCI... No wait, what year is it, 2558? Oh the 'good old days' of the future, lol.
But seriously, what are you trying to capture? It would appear that your Hauppauge WinTV-PVR-500 is PAL based and only supports the 720x576 PAL 50i SD resolution, anything else will likely return that error message. (if you move that 'Error' message window out of the way, we will likely see what the issue might be).
IceStream wrote:@ meen1230
Ice Thanks for feedback me Ice. And yes it's Windows XP PCI CARD LOL I just want to make live stream using my camera and capture by this PCI Card And live stream using Vmix 12 I've try to use advice resolution from error that message. 720 x 576 I've try another capture program and it's work But it's still not working Vmix.. T_T meen1230 attached the following image(s):  Vmix Error.png (66kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
@ meen1230
What happens if you set the "Frame Rate" to 50i or 25p? I can only assume your camera is also PAL 720x576 50i and/or 25p??? (what make and model is your camera?) Also, what "other" capture program are you referring to where it works? (Hauppauge proprietary program perhaps???, sometimes their hardware is only designed to work with 'their' software).
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
thats vmix trial version 12? what the? and XP? you need to step it up a notch, i think support ended a long time ago. and your running a crack i bet.
hellokitty wrote:thats vmix trial version 12? what the? and XP? you need to step it up a notch, i think support ended a long time ago. and your running a crack i bet. No i'm not using crack I have Vmix 12 Installation just use TRIAL Version 60 days And it's not windows XP It's windows 7 that theme just look like XP.
