elshorbagy
#1 Posted : Friday, May 29, 2015 12:45:09 PM(UTC)
elshorbagy
I read in the help file that to capture and output at the same time with Decklink I will need two or more devices, one for each. So, I need 2 cards to get my input and generate output, right?
Is that limitation related only to Decklink and Intensity cards, or for any other card?
Thank you
Ittaidv
#2 Posted : Friday, May 29, 2015 1:00:51 PM(UTC)
Ittaidv
elshorbagy wrote:
Thank you
Depends on the card, some have 2 or more in/outputs on a single card. There's many decklink models, you can check them on the blackmagic website. If you need a simple output, buy a decklink mini monitor card (145$), this gives you HDMI or SDI out.
