Use Decklink card as input and output at the same time
I read in the help file that to capture and output at the same time with Decklink I will need two or more devices, one for each. So, I need 2 cards to get my input and generate output, right?
Is that limitation related only to Decklink and Intensity cards, or for any other card?
Thank you
Joined: 12/19/2013(UTC) Posts: 600   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
elshorbagy wrote:Hello,
Thank you Depends on the card, some have 2 or more in/outputs on a single card. There's many decklink models, you can check them on the blackmagic website. If you need a simple output, buy a decklink mini monitor card (145$), this gives you HDMI or SDI out.
